looking for better router
- looking for better router
08-07-2013 4:58 PM
hi im looking for a better router I have fibre broadband and was wondering if it was possible to use another router say like the new bt home hub for better wifi range
or would it be better buying one of the wifi plugs that extends the range
thanks
ade
thanks
ade
Message 1 of 3
(691 Views)
2 REPLIES 2
Re: looking for better router
08-07-2013 7:02 PM
It depends on what you want to spend i ve got the asus rt-n66u like many others on here and its brilliant but its around the £100 mark
Message 2 of 3
(344 Views)
08-07-2013 10:04 PM
I also got a rt-n66u, you can't got wrong with this router, very very good wifi range.
Message 3 of 3
(344 Views)
