login
noddy8
login
Hi this is actually for my son who's had plusnet for years but having problems with the router which looks as if it's about to give up , he can't remember his password to set up a new router any quick ways of getting it to show  on his old one ? cheers
Fixes: 156
Re: login
It's the same as his member centre one
Customer / Moderator / If it helped click the thumb / If it fixed it click 'This fixed my problem'
noddy8
Re: login
that's the problem it's so long since he's needed it he just can't remember Sad
Fixes: 62
Re: login
