line speed update
matty2k13
line speed update
hello, please will a admin do me a line speed update
thanks in advance Cheesy
matty2k13
Re: line speed update
Changed my adsl filter and synced at 6166kbps and line profile is only 4.9mb
If im correct then is should be around 5.33mb or something.
Fixes: 16
Don't you want the excitement and suspense of waiting to see if it happens automatically or not?  Tongue
matty2k13
how long will that take ?
Fixes: 16
The suspense is provided by the element of waiting and seeing. It's supposed to happen after a few hours: http://community.plus.net/forum/index.php/topic,101517.msg987604.html#msg987604 Or it might not happen for some inexplicable reason.
Fixes: 58
My opinion from personal experience and many other posts on here is that the BT delta reports are still tied to the old 20CN blip logic so that a change can take 3 days to generate the report which Plusnet act on within a few hours
matty2k13
i have just orderd a XTE-2005 adsl nation faceplate, anyone got one and if so does it improve your line speed
matty2k13
just done the test on bt and got this
Download speedachieved during the test was - 4.93 Mbps
For your connection, the acceptable range of speeds is 2 Mbps-7.15 Mbps.
IP Profile for your line is - 5.31 Mbps
but plusnet still have it at 4.9mb
I've changed that for you now.
matty2k13
profile changed to 5.3mb and speedtest shows only 4.7mb, is that right ?
matty2k13
router synced at 6166kbps
Try that again, is seems an update had come through that had lowered your profile.
