line attenuation
craig_p
line attenuation
Hi
I have a line att of 50 db downstream and a noise margin of 0 to 3 db
Is this OK as i have read something about it needing to being 6db. I have no probs with dropped  connections.
21 REPLIES 21
Oldjim
Resting Legend
Fixes: 63
Re: line attenuation
Sounds like a duff reading.
Out of interest what sort of errors is your router reporting and what is your sync speed.
craig_p
hi
not sure where to look for router errors on my netgear dg384g v2. the sync speed varies between 3000 and 4500 but is stable around 3500.
James
Hi Craig,
If your connection is working fine, then I wouldn't worry too much about it.
craig_p
Wow James, that was quick. Its not that ive had probs but the speed changes quite a lot over several days but dosn't seem to affect COD4 on x box live So if it aint broke i won' fix it.
Oldjim
Resting Legend
Fixes: 63
If your speed changes quite a lot without you doing anything it means that your router is losing sync frequently - not good
To get the information try RouterStats which will give you all the information you need and also allow you to monitor speeds and noise margin. The noise margin may be a little more accurate than the router figures as it uses it's own algorithm. Note it is preconfigured for your router model.
pierre_pierre
I dont think my one is that comprehensive Jim is it OK though? Smiley Smiley Cool Roll_eyes
Oldjim
Resting Legend
Fixes: 63
Bragging does not become you   Roll_eyes Roll_eyes
craig_p
Hi
got the router stats software working and the noise margin hovers around 2 db. Just re booted it after complaints from son no 2 regarding C.O.D 4 being slow. Its now gone up to 9db and his connection it much better. Any ideas
Craig
Oldjim
Resting Legend
Fixes: 63
if it was sitting at 2dB noise margin you were almost certainly getting a very high error rate which would seriously mess up on line gaming
craig_p
Angry I found that out to from son no 2!!! but I still don't know why. Do i need to raise a ticket for this or is there anything I can try at home.
craig
James
You said earlier it was sat at 9dB and all was fine.
Is that no longer the case?
craig_p
HiJjames
I have just come back to check and it was showing -2 db until I started to use the connection and its now jumping up and down like a kangaroo between -2 and 9.
craig_p
Hi
Just noticed that as soon as son no 2 switched on his pc which is hard wired to the router, the noise margin dropper like a stone to 1-2 db. Could this be caused by the network cable going through the same trunking as the phone cable? Angry
scootie
have you got a spare router to try and see if that reports the same snr and have you tried pluging the router into the test socket of your bt master socket to see what line stats you get.
