line attenuation
- line attenuation
line attenuation
23-10-2008 3:09 PM
I have a line att of 50 db downstream and a noise margin of 0 to 3 db
Is this OK as i have read something about it needing to being 6db. I have no probs with dropped connections.
Re: line attenuation
23-10-2008 3:12 PM
Out of interest what sort of errors is your router reporting and what is your sync speed.
23-10-2008 4:35 PM
not sure where to look for router errors on my netgear dg384g v2. the sync speed varies between 3000 and 4500 but is stable around 3500.
23-10-2008 4:35 PM
If your connection is working fine, then I wouldn't worry too much about it.
23-10-2008 4:39 PM
23-10-2008 4:54 PM
To get the information try RouterStats which will give you all the information you need and also allow you to monitor speeds and noise margin. The noise margin may be a little more accurate than the router figures as it uses it's own algorithm. Note it is preconfigured for your router model.
23-10-2008 5:02 PM
23-10-2008 5:08 PM
28-10-2008 3:42 PM
got the router stats software working and the noise margin hovers around 2 db. Just re booted it after complaints from son no 2 regarding C.O.D 4 being slow. Its now gone up to 9db and his connection it much better. Any ideas
Craig
28-10-2008 3:50 PM
28-10-2008 6:11 PM
craig
28-10-2008 6:12 PM
Is that no longer the case?
28-10-2008 7:13 PM
I have just come back to check and it was showing -2 db until I started to use the connection and its now jumping up and down like a kangaroo between -2 and 9.
29-10-2008 10:50 AM
Just noticed that as soon as son no 2 switched on his pc which is hard wired to the router, the noise margin dropper like a stone to 1-2 db. Could this be caused by the network cable going through the same trunking as the phone cable?
29-10-2008 7:02 PM
