turn on suggestions
level3 vs colt.net
- level3 vs colt.net
level3 vs colt.net
level3 vs colt.net
03-06-2014 3:00 PM
randomly getting different routing that normally goes via level3 which is using colt.net which dead ends at cpeuk_lon066223.ia.colt.net
edit: I was getting it to USA sites but no longer, only one that is 100% of the time is www.national-lottery.co.uk
edit mk2 trace added
Unvalued customer since 2001 funding cheap internet for others / DSL/Fibre house move 24 month regrade from 8th May 2017
Re: level3 vs colt.net
03-06-2014 8:23 PM
FWIW I've just got The National Lottery site here OK, but trying to log in failed to work. Traceroute went nowhere near COLT, but there was a huge jump to 200+ms where the trace left PN and on to Level 3.
C:\Users\Brian>tracert www.national-lottery.co.uk
Tracing route to www.lb.national-lottery.co.uk [213.146.190.183]
over a maximum of 30 hops:
1 <1 ms <1 ms <1 ms 192.168.0.1
2 * * * Request timed out.
3 23 ms 23 ms 23 ms lo0.10.central10.ptw-bng01.plus.net [195.166.128.170]
4 23 ms 46 ms 23 ms irb.10.ptw-cr01.plus.net [84.93.249.1]
5 144 ms 222 ms 231 ms te-3-4.car5.London1.Level3.net [217.163.45.181]
6 24 ms 24 ms 24 ms ae-51-51.csw1.London1.Level3.net [4.69.139.88]
7 24 ms 24 ms 24 ms ae-117-3503.edge3.London1.Level3.net [4.69.166.138]
8 25 ms 25 ms 25 ms be3043.ccr22.lon01.atlas.cogentco.com [130.117.15.245]
9 26 ms 27 ms 24 ms te3-8.ccr01.lon10.atlas.cogentco.com [154.54.75.66]
10 24 ms 24 ms 32 ms te3-2.ccr01.lon15.atlas.cogentco.com [154.54.57.234]
11 25 ms 25 ms 25 ms te3-2.ccr01.lon14.atlas.cogentco.com [154.54.58.49]
12 25 ms 25 ms 25 ms te0-6-0-3.rcr21.lhr01.atlas.cogentco.com [130.117.51.185]
13 26 ms 26 ms 26 ms te1-2.mag01.lhr01.atlas.cogentco.com [130.117.0.194]
14 * * * Request timed out.
30 * * * Request timed out.
Trace complete.
03-06-2014 8:40 PM
It seems to go through colt.net when using port 80.
adw@thunderbolt:~$ tcptraceroute.mt www.national-lottery.co.uk 80
Selected device wlan0, address 10.0.1.26, port 33312 for outgoing packets
Tracing the path to www.national-lottery.co.uk (194.246.78.103) on TCP port 80 (http), 30 hops max
1 10.0.1.1 1.153 ms 0.950 ms 11.190 ms
2 lo0-central10.pcl-ag07.plus.net (195.166.128.188) 24.387 ms 32.417 ms 26.324 ms
3 link-b-central10.pcl-gw02.plus.net (212.159.2.186) 27.569 ms 27.814 ms 49.058 ms
4 xe-9-0-0.pcl-cr02.plus.net (212.159.0.218) 25.887 ms 26.544 ms 23.575 ms
5 ae2.pcl-cr01.plus.net (195.166.129.6) 42.409 ms 26.577 ms 25.963 ms
6 ae1.ptw-cr01.plus.net (195.166.129.0) 26.278 ms 26.958 ms 26.152 ms
7 linx-ge7-0-oscar.lon.router.colt.net (195.66.224.49) 25.459 ms 49.615 ms 28.648 ms
8 * * *
9 cpeuk_lon066223.ia.colt.net (80.169.144.146) 24.872 ms 27.568 ms 24.680 ms
10 194.246.78.103 [open] 26.745 ms 25.886 ms 33.834 ms
F9 member since 4 Sep 1999 F9 ADSL customer since 27 Aug 2004 DLM manages your line the same way DRM manages your rights. Look at all the pretty graphs! (now with uptime logging!) | ![]() |
