laughable speed results.
- laughable speed results.
20-10-2009 7:45 PM
My result was 9.35mb which is strange considering my sync is 5728Kbps Second test gave 9.5mb
Guess some companies could use these unreliable results from here to make their services look good.
Podman
Re: laughable speed results.
20-10-2009 8:13 PM
20-10-2009 9:34 PM
My line syncs at around 4.5mb, and my profile is 4mb I think. So either that's wrong, or i'm still getting slow naff speeds.
It also claims fastest in my area is Virgin. er. We can't get cable. the nearest is around 5 mile away.
Next is 02 at 6.5, and talktalk at 3.8
Plusnet comes out at 3.3mb. A bit of an increase from my 1.6 download. Naturally I don't believe these results, but do believe there's still odd speed issues at the moment.
20-10-2009 9:41 PM
Also it shows a house up the road from me as having a Sky connection which downloads at 85Mb and uploads at 58Mb. Almost next door is a PN connection running at 0.7Mb!
20-10-2009 9:56 PM
20-10-2009 9:58 PM
@SteveA - I'm almost certain that whoever tested that Sky connection will have been running Kaspersky AV - it has a habit of grossly over-inflating speedtest results for some reason
20-10-2009 10:38 PM
21-10-2009 7:10 AM
21-10-2009 7:29 AM
It is clearly bollox
EDIT: I've just used their contact system to question them on it.
21-10-2009 10:32 PM
22-10-2009 10:40 AM
They may even be using different files for different suppliers - using a compressed (but "empty") Word 97 file could change the speed by a factor of 20
