last couple of days my speed both upload and download has dropped off
- last couple of days my speed both upload and downl...
13-05-2014 5:51 PM
Re: last couple of days my speed both upload and download has dropped off
14-05-2014 9:35 AM
I can't see any change on your connection, your profile has been around 2.6Mb/s for a while.
If you run a speed test at http://speedtest.btwholesale.com what speeds does this report?
14-05-2014 9:46 AM
DSL Connection
Link Information
Uptime: 23 days, 22:12:39
DSL Type: ITU-T G.992.3
Bandwidth (Up/Down) [kbps/kbps]: 857 / 2.969
Data Transferred (Sent/Received) [MB/GB]: 820,10 / 1,99
Output Power (Up/Down) [dBm]: 12,7 / 0,0
Line Attenuation (Up/Down) [dB]: 35,4 / 60,0
SN Margin (Up/Down) [dB]: 6,0 / 4,8
Loss of Signal (Local/Remote): 2 / 0
Loss of Link (Remote): -
Error Seconds (Local/Remote): 26.603 / 0
FEC Errors (Up/Down): 33.019 / 2.308.458.305
CRC Errors (Up/Down): 8.768 / 68.101
HEC Errors (Up/Down): 9.819 / 635.812.
14-05-2014 11:08 AM
14-05-2014 11:42 AM
14-05-2014 11:46 AM
14-05-2014 11:52 AM
14-05-2014 12:37 PM
14-05-2014 3:13 PM
14-05-2014 4:34 PM
DSL Connection
Link Information
Uptime: 0 days, 4:08:24
Bandwidth (Up/Down) [kbps/kbps]: 833 / 3.463
Data Transferred (Sent/Received) [MB/MB]: 91,93 / 650,20
Output Power (Up/Down) [dBm]: 12,6 / 0,0
Line Attenuation (Up/Down) [dB]: 35,5 / 60,5
SN Margin (Up/Down) [dB]: 6,4 / 2,9
Error Seconds (Local/Remote): 23 / 0
FEC Errors (Up/Down): 580 / 355.654
CRC Errors (Up/Down): 24 / 32
HEC Errors (Up/Down): 21 / 164
14-05-2014 5:09 PM
14-05-2014 5:19 PM
Is the target SNRM for this line 3dB?
The DS attenuation is way over Chris Pettitt's 45dB 'rule of thumb' for ADSL2 being beneficial. Is there any merit in moving this line to ADSL(1)?
@Chrsigiltnane,
Given that you are getting a marked increase in synch in the test socket, there is some possibility that there is an issue with you internal wiring. Can you please confirm if you have a phone extension and how it is (they are) wired?
Kevin
14-05-2014 5:39 PM
Don't know the answer to your first question. I just want the best speed i can get given the lack of high speed connectivity in the area. As I say I have had 2.8 to 2.9 consistantly for months and it has only recently dropped down to 2.4 to 2.6
14-05-2014 6:07 PM
Can you please confirm which of these is your master socket - https://portal.plus.net/support/broadband/master-socket-guide.shtml - and that the removed faceplate has no wires attached to it?
@DCT,
If this looks like a BT supplied ADSL filter issue, is this a call out job or a "stay connected to the test socket" fix? The synch speed in the test socket is markedly higher than what might be reasonably expected on a line having this attenuation.
Please do not forget my ADSL(1) question above.
Kevin
14-05-2014 6:18 PM
Quote from: Townman The DS attenuation is way over Chris Pettitt's 45dB 'rule of thumb' for ADSL2 being beneficial. Is there any merit in moving this line to ADSL(1)?
This rule of thumb is probably a load of rubbish, I suspect it has nothing to do with the technical characteristics of ADSL2, ADSL2 should be greater than or equal to ADSL1 for all line lengths. It probably has more to do with Plusnet not wanting your low speed to be lowering the average for their "up to 24M" speeds. They would rather have your low speed included in the up to 8M group. If not I would be interested in seeing some actual data rather than anecdotal assertions.
And for the very longest lines, ADSL2 should provide slightly more bandwidth because it can use tones that can only support having 1 bit allocated to them, whereas ADSL1 requires a tone to have sufficient SNR for at least 2 bits.
