kensfishbar: broadbad speed is only half of used to be. (customer)
kensfishbar
I have also noticed that the upload speed is also only half of what I was with the other ISP and the first few days with PlusNet.    My line is definitely can do more than 1Mb up but why it is set to half meg now?
Fixes: 58
because someone pressed the wrong button when ordering it
Fixes: 126
Re: kensfishbar: broadbad speed is only half of used to be. (customer)
Moderators Note.
split from other thread for better visibility.
Will Moderate For Thanks
Fixes: 136
Your upload speed is uncapped as your currently syncing at 648kbps.
I can see you currently have a fault raised. We'll investigate that ASAP.
 Matthew Wheeler
