keep disconnecting every 10 mins
reece251
so ive just gone live and my internet keeps dropping every so often and the only way to get it back on is by rebooting the router through the gui. its a netgear router and im using wireless on adsl. Only just got up and running so its annoying it keeps dropping. any tips?
reece251
Re: keep disconnecting every 10 mins
I've just been advised that it's because of the training period is this true? Has anyone else experienced frequent disconnections during the training period
scoobydoo1
are you using wireless, or wired? if wireless turn it off, n just use wired, see if that helps
reece251
I've found out that the wireless kept dropping every so often but wired is Ok iI do need wireless for my other devices tho. The adsl and Internet lights stay on but I just cannot access the Internet even tho I am connected wirelessley to the router
kirk
Try changing your wireless channel. To do this:
Log in to the modem router at its default LAN address of http://192.168.0.1 with its default user name of admin and default password of password, or using whatever LAN address and password you have set up. Select the Wireless Settings in the main menu. The Wireless Settings screen displays. Then you should be able to change the wireless channel.
Give that a go and see if it resolves the issue.
Plusnet Staff
Plusnet Staff
Fixes: 5
Hi reece251,
What's the model of your Netgear Router?
Chris Pettitt
Cloud Environments Engineer
reece251
It's a netgear dgn1000
Plusnet Staff
Plusnet Staff
Fixes: 5
That router should be fine.
I would certainly wait for the 10 day training period to end. This will allow your connection time to settle in and stabilise. If you're having problems primarily with wireless, it might be worth looking to see if you have any updates for your Wireless Card (Please see your Wireless Card manufacturer's website for further information on this.)
If this is up to date, are you able to change the Wireless Channel, as kirk as suggested?
Chris Pettitt
reece251
Everything's up to date the trouble is I stay connected to the router so on all my devices it shows as connected to my router but Ijust ccan't access the Internet after 10 mins. I have changed to wireless channel 6 and need to wait an hour to see if the connection holds
Plusnet Staff
Plusnet Staff
Fixes: 5
Ok. Let me know how you get on. Fingers crossed the change in wireless channel should do the trick.
Chris Pettitt
reece251
This is the longest it's been connected via wireless but I'm not signing and dancing yet =p thanks for the amazing support as well chris
kirk
Hopefully the wireless connection will hold now you have changed the wireless channel  Smiley
reece251
its coming up to an hour now and everythings holding. thanks kirk and chris. I do wonder what was interfering with my router
reece251
how the hell am i getting at least 1mb download speed when downloading. im really suprised with my speed to be honest. thats a nice suprise i thought it was going to be a useless download speed
Plusnet Staff
Plusnet Staff
Fixes: 5
That sounds about right, given the speed estimate for your line.
Chris Pettitt
