just noticed new interleaving menu on member centre.
- just noticed new interleaving menu on member centr...
11-12-2008 10:53 PM
just noticed i have the interleaving menu now. yet it say's interleaving is on but dmt its still saying on fastpath which is what it should be.
any ideas as to why it would say interleaving on.
Message 1 of 6
(1,136 Views)
5 REPLIES 5
Re: just noticed new interleaving menu on member centre.
12-12-2008 9:39 AM
Where did you find this on menus? I have just looked at my router stats and I've noticed that interleaving is on - it wasn't before but I can't find the option to switch off in Members centre.
Message 2 of 6
(463 Views)
12-12-2008 9:44 AM
If it's on you can't turn it off yourself, so the option isn't visible.
I vaguely recall my member centre was once "out of sync" regarding interleaving, I guess there's a minor bug somewhere.
Message 3 of 6
(463 Views)
12-12-2008 10:11 AM
A further point tho' - I'm sure that my router was showing " G.DMT - fast" - its now showing "G.DMT - Interleave" - I haven't reported any problems,( I'm synching at 8128/448 ,my D/S Attn =20 and SNR =8.8)so why/who would have turned it on?
Message 4 of 6
(463 Views)
12-12-2008 10:20 AM
I can't remember the circumstances where it would appear in your member centre TBH, I'll check over your account when I get out my next meeting and have a look.
@brewerdave
It's more than likely set to auto, so if the line conditions have changed it might have come on to combat that.
@brewerdave
Message 5 of 6
(463 Views)
12-12-2008 11:26 AM
Quote If it's on you can't turn it off yourself, so the option isn't visible
Not entirely true
The button, IIRC, simply raises a ticket on your account to have interleaving turned off. If the button isn't visible, you can request that interleaving be turned off here.
Or navigate there:
Help and Support>Help Assistant>My Broadband Connection>(login)>DSL Max Interleaving
Message 6 of 6
(463 Views)
