just had a stale session on a gateway after a clean reboot
Did a clean router reboot just now and the first gateway I got, there was zero through traffic or could I trace anything, note I did not get a BT IP address.  Currently on ptn-bng01 after a gateway hop.
Unvalued customer since 2001 funding cheap internet for others / DSL/Fibre house move 24 month regrade from 8th May 2017
Fixes: 69
Re: just had a stale session on a gateway after a clean reboot
Hi Gus,
There should be no possibility of a stale session. I suspect you might have hit a BT landing page perhaps due to a fault. Did your record the IP you saw?
 Adam Walker
pwatson
Sounds very similar to the problem I had a few weeks ago -
http://community.plus.net/forum/index.php/topic,127467.msg1107988.html
(Not the flaky bit, but the next part where I had no connectivity beyond the PN gateway)
Adam nope I got my normal static IP, one of the first things I checked
