issues viewing or accessing certain websites such as glass suppliers
mark99
Been having issues connecting to certain websites, at the moment I am having to use a VPN to connect to those websites, it appears the issue is with plus net
anyone have any ideas ? as it appears it is no longer possible to submit a support ticket and phoning plus net takes forever to get through not really good enough considering the adverts on the TV (possible breach of advertising terms with false claims)
I have rebooted and restarted wifi box, cleared cache files not sure what else I can do other than switch to another company rather than living in a VPN
Sites are glass sites and other non adult sites
Tags (1)
4 REPLIES 4
Gel
Aspiring Champion
Fixes: 29
Re: issues viewing or accessing certain websites such as glass suppliers
Try this; depending on router, change the DNS settings to
8.8.8.8
8.8.4.4
which are Google's. If you've a PN Hub One you can't do that so will need to amend each devices Network settings to achieve.
Let us know if it helps Smiley
mark99
Hi thanks,
however using googles dns entries is not a long term solution ?? is there any other idea?
thanks mark
Chris
Legend
Fixes: 169
Hi Mark,
Sorry for the problems you're having.  Which router is it you're using?
mark99
hi
it is the netgear n600
thanks
