issues viewing or accessing certain websites such as glass suppliers
- Re: issues viewing or accessing certain websites s...
25-10-2016 10:39 AM
Been having issues connecting to certain websites, at the moment I am having to use a VPN to connect to those websites, it appears the issue is with plus net
anyone have any ideas ? as it appears it is no longer possible to submit a support ticket and phoning plus net takes forever to get through not really good enough considering the adverts on the TV (possible breach of advertising terms with false claims)
I have rebooted and restarted wifi box, cleared cache files not sure what else I can do other than switch to another company rather than living in a VPN
Sites are glass sites and other non adult sites
Re: issues viewing or accessing certain websites such as glass suppliers
25-10-2016 10:42 AM
8.8.4.4
which are Google's. If you've a PN Hub One you can't do that so will need to amend each devices Network settings to achieve.
Let us know if it helps
25-10-2016 10:51 AM
Hi thanks,
however using googles dns entries is not a long term solution ?? is there any other idea?
thanks mark
25-10-2016 2:18 PM
Hi Mark,
Sorry for the problems you're having. Which router is it you're using?
25-10-2016 2:51 PM
hi
it is the netgear n600
thanks
