issues again
greenbrucelee
issues again
So I refer to my previous thread as I have replied to it
https://community.plus.net/t5/Broadband/Link-to-Broadband-Fault-checker/td-p/1457959
Problem has returned I believe there must be a fault with the box down the road or the exchange.
11 REPLIES 11
Chris
Legend
Fixes: 169
Re: issues again
Can you give a bit of detail about the issue you're seeing at the moment? Testing your line is showing that the most recent BT Speedtest was at 4.6Mb/ which is bang in the middle of your line estimates.
greenbrucelee
Re: issues again
yeah 4.6 is in the middle but dropping to 2.4 and 1.4 isn't good. It seems everytime there is work on the box down the road my internet speeds suffer.
Fixes: 1,600
Re: issues again
It looks like your speeds may be restricted by the IP profile of 2.5mbps. I've just reset your line now. Can you reboot your router in about 4 hours please? I've also left the fault ticket open so that our faults team will follow up over the next 72 hours.
Anoush
greenbrucelee
Re: issues again
I will have to wait till I get home from work which will be about 9pm then I will reset it.
greenbrucelee
Re: issues again
why does this keep happening?
Fixes: 1,600
Re: issues again
I'm not entirely sure and it doesn't look like it's gone through.
I've contacted our suppliers to reset your line from their end.
That should complete within 4 hours and take a further 24 hours for the line to stabilise.
greenbrucelee
Re: issues again
just done a speed test again got 6.82Mbps so it could be sorted. I will monitor it.
Fixes: 1,600
Re: issues again
Happy to hear that!
Keep us in the loop.
Cheers
greenbrucelee
Re: issues again
2.62Mbps tonight. Will keep monitoring.
Fixes: 160
Re: issues again
It's router stats which need to be monitored. Data speed test results can be variable due to numerous factors.
Fixes: 1,600
Re: issues again
The IP profile is aligned correctly now at
BRAS Profile: adsl7150
Your router is in sync at 3mbps so I'd expect your throughput to be around 2.62mbps.
And your connection is stable.
Unfortunately as the sync speed falls within the estimated speed for your line, there's little that we can do to improve on that.
