is line capped
goatty2
is line capped
was on 40/10 40gb
moved the phone to PN and was put on unlimited but no increase in speed.
before
after
Dick:green Image tags added.
gnicholson8
Re: is line capped
What does it say on here http://www.dslchecker.bt.com/ is the max available for your line
goatty2
Re: is line capped
Hi gnicholson8
seams like  speed gone down since going onto unlimited
BT BROADBAND AVAILABILITY CHECKER
Featured Products
                                            Downstream Line Rate(Mbps)          Upstream Line Rate(Mbps)      Downstream Range(Mbps)        Availability Date
                                                      High        Low                                              High          Low
FTTC Range A (Clean)            27.9        27.9                                                5.7            5.7                                    --                                      Available
FTTC Range B (Impacted)      27.9        27.9                                                5.7              5.7                                        --                                  Available
WBC ADSL 2+                        Up to 5      --                                                4 to 6        Available
gnicholson8
Re: is line capped
Okay, so according to that your max line speed is just shy of 30Mbps so you're actually getting better than expected.
can you try running a speedtest at this link,
http://speedtest.btwholesale.com/
Go to further diagnostic and then entering the details. It will then give you a IP profile speed and gives you the information of what you should achieve.
goatty2
Re: is line capped
1. Best Effort Test: -provides background information.
Download Speed
37.48 Mbps
0 Mbps 38.97 Mbps
Max Achievable Speed
Download speedachieved during the test was - 37.48 Mbps
For your connection, the acceptable range of speedsis 16 Mbps-38.97 Mbps .
Additional Information:
IP Profile for your line is - 38.97 Mbps
Upload Speed
5.02 Mbps
0 Mbps 20 Mbps
Upload speed achieved during the test was - 5.02Mbps
gnicholson8
Re: is line capped
It does look like you're at your maximum achievable speed.
goatty2
Re: is line capped
when  first checked out fibre bt said line get 53 m .i started with the 40/10 package which restricted speed to 40, so thought it would increase when moved onto the unlimited package. so stuck with this speed  Sad
thanks for your help
gnicholson8
Re: is line capped
yeah, I am just going by what the dslchecker says is available for your line.
Fixes: 62
Re: is line capped
Looking at your IP profile you are hitting the top of the 40/10 range so it may well be worth moving to 80/20
I am sure it will be picked up in the morning
This won't increase the upload speed but it may get a bit more download
gnicholson8
Re: is line capped
yeah but the DSL checker says his fastest available speed is 27Mbps :/ so will he get much more?
Fixes: 62
Re: is line capped
The checker is not relevant in this case - it is notoriously dodgy - the fact that he is hitting 40Mbps now indicates that he may be able to get more
gnicholson8
Re: is line capped
ahhh I see, so it looks like PN didn't update his IP profile and speed when he upgraded to unlimited.
Fixes: 62
Re: is line capped
Not quite
A move to unlimited only involves a change of product from 40/10 to 80/20 when it is believed that speeds in excess of 40Mbps can be achieved. As the checker is apparently so badly adrift they would have assumed that there would be no benefit in moving to 80/20 so the line is still provisioned at 40/10 which is what needs to be changed. This is done via BT Openreach
Fixes: 51
Re: is line capped
The upload diagnostic test shows the line is provisioned on 20Mbps upload so I would expect the user is already on an 80/20 service.
David
Re: is line capped
Yep, as of 11th November the OP has been on the 80/20 service so I'm afraid things are about as good as they'll get.
