is line capped
- Re: is line capped
is line capped
26-11-2013 6:51 PM
moved the phone to PN and was put on unlimited but no increase in speed.
before
after
Dick:green Image tags added.
Re: is line capped
26-11-2013 7:00 PM
Re: is line capped
26-11-2013 8:49 PM
seams like speed gone down since going onto unlimited
BT BROADBAND AVAILABILITY CHECKER
Featured Products
Downstream Line Rate(Mbps) Upstream Line Rate(Mbps) Downstream Range(Mbps) Availability Date
High Low High Low
FTTC Range A (Clean) 27.9 27.9 5.7 5.7 -- Available
FTTC Range B (Impacted) 27.9 27.9 5.7 5.7 -- Available
WBC ADSL 2+ Up to 5 -- 4 to 6 Available
Re: is line capped
26-11-2013 8:58 PM
can you try running a speedtest at this link,
http://speedtest.btwholesale.com/
Go to further diagnostic and then entering the details. It will then give you a IP profile speed and gives you the information of what you should achieve.
Re: is line capped
26-11-2013 9:11 PM
Download Speed
37.48 Mbps
0 Mbps 38.97 Mbps
Max Achievable Speed
Download speedachieved during the test was - 37.48 Mbps
For your connection, the acceptable range of speedsis 16 Mbps-38.97 Mbps .
Additional Information:
IP Profile for your line is - 38.97 Mbps
Upload Speed
5.02 Mbps
0 Mbps 20 Mbps
Upload speed achieved during the test was - 5.02Mbps
Re: is line capped
26-11-2013 9:21 PM
Re: is line capped
26-11-2013 9:47 PM
thanks for your help
Re: is line capped
26-11-2013 9:52 PM
Re: is line capped
26-11-2013 9:58 PM
I am sure it will be picked up in the morning
This won't increase the upload speed but it may get a bit more download
Re: is line capped
26-11-2013 10:04 PM
Re: is line capped
26-11-2013 10:06 PM
Re: is line capped
26-11-2013 10:08 PM
Re: is line capped
26-11-2013 10:16 PM
A move to unlimited only involves a change of product from 40/10 to 80/20 when it is believed that speeds in excess of 40Mbps can be achieved. As the checker is apparently so badly adrift they would have assumed that there would be no benefit in moving to 80/20 so the line is still provisioned at 40/10 which is what needs to be changed. This is done via BT Openreach
Re: is line capped
26-11-2013 11:01 PM
Re: is line capped
27-11-2013 11:38 AM
