is it likely that my modem always connects at 7127 Kbps?
- is it likely that my modem always connects at 7127...
17-11-2009 8:08 AM
or am i locked at some rate?
Re: is it likely that my modem always connects at 7127 Kbps?
17-11-2009 8:24 AM
if your on a banded profile it's likely to be 4864-9728kbps as your just below the next one up http://community.plus.net/library/broadband/dynamic-line-management-dlm-on-adsl2/
17-11-2009 8:28 AM
but for a week or 2 now i've been stuck at exactly that speed even after restarts, this seems unlikely to me
but then i don't really know how the underlying hardware protocol works
but i am suspicious that i'm being somehow held down at that speed even though i've had no drops other than my own manual ones....
17-11-2009 8:32 AM
Quote The below image will show you all of the various different banded profiles that are currently on WBC/WBMC.
wouldnt put it past BTw to sneak some more in
if your syncing spot on the same sync every time then it does point at a band but normaly fixed syncs tend to be when your line can sync out side the band so hence gets held back to the top end of the band, wonder if the comms can double check this for you. i belive james use to be able to tell people for sure if they was or wasnt on a banded profile
17-11-2009 8:41 AM
-T
17-11-2009 8:45 AM
so to test have to restart and not going to do that in a hurry as the dlm will no doubt pick a fight with me again 😉
dick:quote
17-11-2009 8:49 AM
and if bt have diff versions on diff exchanges
and how their release management procedure works...
still on the plus side looks like i'm going to start a new developer job soon so will be too busy again
unless working from home goes wrong
fyi james said i'd been put on a band because of drops i was having a few weeks ago, but i've not managed to get out of jail since then ...
17-11-2009 8:57 AM
where they showed this http://www.simonscat.com/catmando.html
and now moved onto watching them very funny
17-11-2009 9:12 AM
Have you been released from banding yet?
17-11-2009 9:15 AM
bt really need to consider giving us end users more control over this...
jim:quote
17-11-2009 10:42 AM
17-11-2009 10:49 AM
My profile is also down to 6000K (not sure if this BT or PlusNet). Also noticed that my SNR/Tone graph (routerstats 5.7) has tones up to 255. Previously I'd see the whole 512 which is what I thought constituted ADSL2+. Curious.
BT Openreach have been ploughin the local roads putting fibre down for the upcoming FTTC at our exchange (Heaton Moor). Wonder if this is related?
-T
17-11-2009 10:57 AM
what router you running if a netgear use the telnet feature on router stats it gives more info and will tell you which modulation you synced with
17-11-2009 11:10 AM
i would guess bt may have been digging about my area too as i'm on the new southgate exchange which is due for caBling 🙂
is there anyway plunet can get bt to remove me from the banding or bump me up back to where i was...
17-11-2009 3:46 PM
-T
