iplayer and tvcatchup on the blink
- iplayer and tvcatchup on the blink
22-11-2009 9:09 PM
down for me says tvcatchup is down
http://www.bbc.co.uk/iplayer/
http://www.tvcatchup.com
typical when you want to watch top gear that both viewing sources go down
edit: iplayer is back up now yepi
edit2 dam it cant get to bbc 2 live stream thoe
Re: iplayer and tvcatchup on the blink
22-11-2009 9:11 PM
22-11-2009 9:13 PM
http://www.bbc.co.uk/iplayer/playlive//
22-11-2009 9:13 PM
Quote The connection was reset
22-11-2009 9:14 PM
22-11-2009 9:17 PM
Quote from: downforeveryoneorjustme It's not just you! http://www.tvcatchup.com looks down from here.
http://downforeveryoneorjustme.com/www.tvcatchup.com
22-11-2009 9:17 PM
i was watching a channel on catchup till 9pm fine and then when to flick over to bbc2 and it kept throwing a werid error back at me
yep i checked with that site before posted. but wanted to double check as iplayer went down bang at the same time
22-11-2009 9:19 PM
Haha na down for maintenance.
22-11-2009 9:25 PM
23-11-2009 12:08 AM
23-11-2009 12:13 AM
