ip profile
- ip profile
ip profile
01-07-2008 8:16 PM
i want someone to look at my ip profile which is 3500kbps
but i sync with the exchange at 5056kbps
i get a throughput of 3189kbps which i think could be at least 1.3 meg slower than what i could get
can you get bt to raise the profile as im sure it should be higher than what it is
many thanks in advance
Message 1 of 5
(1,082 Views)
4 REPLIES 4
Re: ip profile
02-07-2008 10:42 PM
anyone prepared to look into this for me?
Message 2 of 5
(429 Views)
Re: ip profile
02-07-2008 10:47 PM
Quote from: Atomic7431 can you get bt to raise the profile
No they can't, it doesn't work that way, which is maybe why you've had no reply?
Have a good read here: http://community.plus.net/blog/2007/07/02/broadband-speed-faults-how-to-diagnose/
And also explore all the links from that as it's all explained very well.
Message 3 of 5
(429 Views)
Re: ip profile
02-07-2008 10:52 PM
A speed of 5056 should get you a profile of 4000. Are you consistently syncing at 5000ish, or is it recent? If it is recent it may take a few days for BT's systems to catch up, but they will do that automatically. If it is consistent you may have a stuck profile. If you don't see anything helpful on the link HPsauce gave you could try raising a support ticket, then PN can request that BT look into it.
Message 4 of 5
(429 Views)
Re: ip profile
03-07-2008 10:13 PM
i had the profile raised a while back, plusnet managed to get bt to do it, so i know it can be done but lately my sync speed seems to have gone up, so was asking if they would attempt to get the profile raised again but as you say no reply so ill have to make a phone call again, thats how i got it sorted last time.
Message 5 of 5
(429 Views)
