ip profile reset please
ngfletcher1967
We have had a fault on our line since Friday which has just been fixed our ip profile is 0.5 . So instead of waiting 3 days before it goes up can you please reset to about 4 MP.
thanks
Cant believe how much we use our internet its only when you have a slow speed do you realise.
Also can you do what you did before since I was getting great speeds.This is the thread about that
http://community.plus.net/forum/index.php/topic,141031.0.html
ngfletcher1967
Re: ip profile reset please
maybe that should be 5 Mp I have just connected at 5696!!
Max. DSLAM throughput kBit/s 5792 448
Min. DSLAM throughput kBit/s 5504 352
Attainable throughput kBit/s 6676 852
Current throughput kBit/s 5696 448
Fixes: 136
They're matching now.
If you log into your router and disconnect then reconnect that should sort it.
 Matthew Wheeler
ngfletcher1967
Brilliant Smiley Smiley Cheesy getting about 4.5mp thanks again
Fixes: 136
Glad to hear it's sorted.
Let us know if there's anything else we can do.
 Matthew Wheeler
