internet
Lesley85
internet
hi does anyone know how you go about changing password on internet box as a think someone is using my internet
Browni
Aspiring Hero
Fixes: 45
Re: internet
Most Plusnet supplied routers use http://192.168.1.254/ as their homepage, you should be able to change passwords there.
I must have been really bad in a previous life as this was my 3rd ISP in a row that used lithium.
Now you're stuck with me because my new ISP doesn't run a forum Cheesy
Fixes: 162
Re: internet
Hi @Lesley85
There's an option to change the SSID and the wifi password, information about how to do this is available at this link:
https://www.plus.net/help/broadband/router-user-guides/
 Chris Parr
 Plusnet Staff
