internet light red please help
karlhenderson
hi iv got the router 2407n or something like that and all the lights are green besides the internet one which is red
robski1
Fixes: 4
Re: internet light red please help
Have you logged into the router (192.168.1.254 via your browser) and selected connect?
Make sure your user name and password have been entered correctly.
karlhenderson
yes just tried then and saying please make sure username and password right
robski1
Fixes: 4
If you are using the correct username & password then I think you need to contact PlusNet to check that you have the correct details. The only time I had this problem was when I was trying to connect using my old Globalnet password that I forgot had been changed when moving to PlusNet.
geek26
Yep as others have said contact Plusnet about this one. They have live chat & phone support
Full contact details at: www.plus.net/contact
MattyC
Champion
Fixes: 46
I don't think your order had completed at the time of you posting this. You should be able to get online now, though it'd require you to log in and authenticate as others have said.
Matty
