internet light keeps going out on voyager 210
- internet light keeps going out on voyager 210
01-02-2008 6:06 PM
just reading the forums thinking im glad my connection is stable.
then my internet dies look to my router and internet light had gone out dsl signal fine went to router settings and connect to internet connected for 10 secs and died again tried couple more times till now its seems fine.
Any ideas why the internet died but still had a stable dsl signal????
Message 1 of 2
(884 Views)
1 REPLY 1
Re: internet light keeps going out on voyager 210
01-02-2008 8:31 PM
Sometimes the blip is so quick that even though the DSL light doesn't flicker the service can drop - I suspect that this is what's happened in your case.
Unfortunately there could be many reasons for this happening but unless it gets worse I'd say it isn't worth it, just because with it being very infrequent it will be very hard to track down.
Hope that helps,
Hope that helps,
Message 2 of 2
(269 Views)
