internet keeps dropping after 10pm
FIXED- Subscribe to RSS Feed
- internet keeps dropping after 10pm
- « Previous
- Next »
Re: internet keeps dropping after 10pm
16-04-2017 5:57 PM
Considering the xDSL stats do not match the "Profile Info: 4M - 9M ..." details,= im confused m8
so has the standard downstream INP of 1, is that the interleaving ?
and they've set both the downstream and upstream target SNRM to 9 dB.are they fixing this through trial and error or are they guessing ?
thanx
17-04-2017 6:26 PM
I think we now need to await the promised response from @MatthewWheeler
17-04-2017 6:47 PM
i havent heard from @MatthewWheeler or plusnet i had to phone them sending an engineer out on Wed. again
18-04-2017 11:24 AM
@glesgajohn@Townman The only way we can proceed bar what's been done already is to arrange another visit and raise the escalation with BT. We can only do that once it's been booked.
18-04-2017 11:26 AM
19-04-2017 6:29 PM
Hi Guys me again !!!
engineer arrived @ 2.30 left @ 5.30pm, ( so he did put the work in ) he checked line when he arrived kept dropping whilst he was here,
he then checked all fittings in house, said all was ok. then he went to cabinet outside, said there was a fault showing from cabinet to exchange,said he had to swap me onto a new line in cabinet and said it then became stable , checked line from house again said it seems to be more stable, must give the engineer his due. he said he was going to find problem even if it took him all day .( was here for 3 hours )10 out of 10 for effort. So i will have to run it for 24 hours to see if it is stable . i ran a speed test and am getting, He did say i might have to get SNR reset done ,but to wait and see
thanx guys, let you know how it runs and if fault has been fixed .
DWNLD=9.14
UPSTRM=0.89
PING=40.50
and these are my router stats.
Statistics -- xDSL
Mode: | ADSL_2plus | |||
Traffic Type: | ATM | |||
Status: | Up | |||
Link Power State: | L0 | |||
Downstream | Upstream | |||
Line Coding(Trellis): | On | On | ||
SNR Margin (1 dB): | 5.9 | 6.3 | ||
Attenuation (1 dB): | 39.0 | 23.5 | ||
Output Power (1 dBm): | 0.0 | 12.6 | ||
Attainable Rate (Kbps): | 11372 | 1044 | ||
Path 0 | Path 1 | |||
Downstream | Upstream | Downstream | Upstream | |
Rate (Kbps): | 10659 | 1040 | 0 | 0 |
MSGc (# of bytes in overhead channel message): | 59 | 66 | 0 | 0 |
B (# of bytes in Mux Data Frame): | 166 | 32 | 0 | 0 |
M (# of Mux Data Frames in FEC Data Frame): | 1 | 1 | 0 | 0 |
T (Mux Data Frames over sync bytes): | 2 | 1 | 0 | 0 |
R (# of check bytes in FEC Data Frame): | 12 | 6 | 0 | 0 |
S (ratio of FEC over PMD Data Frame length): | 0.4998 | 0.9842 | 0.0 | 0.0 |
L (# of bits in PMD Data Frame): | 2865 | 317 | 0 | 0 |
D (interleaver depth): | 64 | 32 | 0 | 0 |
Delay (msec): | 8 | 8 | 0.0 | 0.0 |
INP (DMT symbol): | 1.00 | 2.00 | 0.0 | 0.0 |
Super Frames: | 26511474 | 24136164 | 0 | 0 |
Super Frame Errors: | 696358 | 8398 | 0 | 0 |
RS Words: | 29435314 | 2074755 | 0 | 0 |
RS Correctable Errors: | 13992 | 49 | 0 | 0 |
RS Uncorrectable Errors: | 70 | 0 | 0 | 0 |
HEC Errors: | 11613291 | 16451 | 0 | 0 |
OCD Errors: | 0 | 0 | 0 | 0 |
LCD Errors: | 0 | 0 | 0 | 0 |
Total Cells: | 92472091 | 9005549 | 0 | 0 |
Data Cells: | 2308147 | 293030 | 0 | 0 |
Bit Errors: | 0 | 0 | 0 | 0 |
Total ES: | 24359 | 2452 | ||
Total SES: | 12148 | 137 | ||
Total UAS: | 21664 | 13150 |
21-04-2017 4:28 PM
hi, just to update this thread, my internet has stopped dropping after last engineer visit, seems to be running ok apart from when i try to watch youtuve or videos online then it buffers, will a SNR reset fix this .
thanks
also thanks to Townman and all who helped me with this problem
cheers
23-04-2017 8:26 AM
Although a DLM reset may make slight changes to the speed and latency of your connection, I wouldn't expect it to have any effect on your ability to watch YouTube, you already have sufficient bandwidth.
Perhaps you just happened to end up on a bad Plusnet gateway, and need to reconnect to get on a different one. If the problem persists, you could try the TBB speedtest and see if there's any substantial difference between the 1x and 6x results.
24-04-2017 10:28 AM
Hope all remains stable for you.
Thanks also to @MatthewWheeler for pushing this through for the right grade engineer.
24-04-2017 4:36 PM - edited 24-04-2017 4:37 PM
24-04-2017 4:55 PM
24-04-2017 5:44 PM
thanks for your help
24-04-2017 8:15 PM
29-04-2017 11:30 PM
RS with the TG modem would be interesting. Change the plot to 7200 points per plot = 10 hours.
i did not want to unplug router while on 10 day monitoring , but will post Townman
- « Previous
- Next »
