internet keeps dropping after 10pm
glesgajohn
my internet keeps dropping after 10pm @night all night
this is plusnet response
*INTERNAL*
WP Product: WBC MAX24 mb/s (ADSL2+ Annex A) Uncapped Upstream
WP Profile: Generic Speed 8600 No Time Out Change
Ellacoya: Service_Offer_59
Connected for 0:39:17
67 drops in last 24 hours
82 drops in last 72 hours
KBD
BRAS 11708 Profile Info WBC 160K - 24M Medium delay (INP 1) 3dB Downstream, UC Medium delay (INP 2) 6dB Upstream (ADSL2+)
Problem Explanation: [NF18] The circuit is not in sync.
Resolution/Recommendation: KBD tests indicate no BTW network fault. Please perform End User checks.
xDSL
Status Circuit NOT In Sync
  Upstream Downstream
Loop loss 23.6 39.5
SNR Margin 0.0 1.8
Errored Seconds 0 1
HEC Errors 0
Speed 653 11744
Maximum Stable Rate 9088 Fault Threshold Rate 7270
MTBR 8502 ILQ R
MTBE (Downstream) 22 MTBE (Upstream) 452
SummaryMGALS Value: 3.17 Mbps | BTW Estimate: 4 Mbps
    • High number of drops, possible DCN issue
    • Line is out of Sync
  • SNR reset has been performed on this connection: 3-399198584300
  • also went to
  • http://192.168.1.254/expert_user.html
  • get this
  • Statistics -- xDSL
    Mode: ADSL_2plus
    Traffic Type: ATM
    Status: Up
    Link Power State: L0
      Downstream Upstream
    Line Coding(Trellis): On On
    SNR Margin (1 dB): 5.1 8.3
    Attenuation (1 dB): 40.0 24.0
    Output Power (1 dBm): 0.0 12.6
    Attainable Rate (Kbps): 10108 376
      Path 0   Path 1
      Downstream Upstream Downstream Upstream
    Rate (Kbps): 9758 398 0 0
    MSGc (# of bytes in overhead channel message): 59 46 0 0
    B (# of bytes in Mux Data Frame): 151 5 0 0
    M (# of Mux Data Frames in FEC Data Frame): 1 16 0 0
    T (Mux Data Frames over sync bytes): 2 3 0 0
    R (# of check bytes in FEC Data Frame): 12 16 0 0
    S (ratio of FEC over PMD Data Frame length): 0.4967 7.2845 0.0 0.0
    L (# of bits in PMD Data Frame): 2641 123 0 0
    D (interleaver depth): 64 4 0 0
    Delay (msec): 8 7 0.0 0.0
    INP (DMT symbol): 1.00 2.00 0.0 0.0
    Super Frames: 103894 93866 0 0
    Super Frame Errors: 1 0 0 0
    RS Words: 13506003 921825 0 0
    RS Correctable Errors: 9824 0 0 0
    RS Uncorrectable Errors: 2 0 0 0
    HEC Errors: 0 0 0 0
    OCD Errors: 0 0 0 0
    LCD Errors: 0 0 0 0
    Total Cells: 38607502 1569848 0 0
    Data Cells: 556016 135556 0 0
    Bit Errors: 0 0 0 0
    Total ES: 1 0
    Total SES: 0 0
    Total UAS: 81 81
  • done bt wholesale speedtest and get
  • dwnld speed =8.35
  • upld speed =0.32
  • ping=67.13
can anyone shed light on this for me please
thank you
ps
also tried diffrent modem still the same
148 REPLIES 148
glesgajohn
Re: internet keeps dropping after 10pm
thats it started dropping out again
Fixes: 160
A quick look through the stats suggests that your DS SNRM is a bit variable.  The line's target is 3dB, but the stats report 1.8 & 5.1dB which suggests the presence of electrical noise.  More about this later if we need to.
Is this a 2704n router?
Is the phone line quiet?
Please perform a quiet line test - dial 17070 select option 2 using a corded phone plugged into the test socket behind the face plate of the master socket. It should be silent. A noisy phone line (or no dial tone) will have a marked adverse impact on the performance of broadband.
If the line is noisy or there is no dial tone, then a PHONE LINE fault needs to be raised with your phone provider. If this is PlusNet, you can report a fault on line using the button below.
Is the router plugged into the master socket?  Are there any phone extensions - if yes please describe how the are wired and what is plugged into them.
Is there any item of electrical equipment which comes on at 10 pm?
@crt can you please provide a radius plot report?
glesgajohn
thanks for reply
Is this a 2704n router= yes
Is the phone line quiet?=yes
Please perform a quiet line test - dial 17070 select option 2-quite=done and quite
Is the router plugged into the master socket?= yes and test socket
 Are there any phone extensions=none dont use a landline
Is there any item of electrical equipment which comes on at 10 pm?= it is free from elec. items/equipment and it has started happening randomly b4 10pm now , but not today so far.
thanks for replying
glesgajohn
thats it started dropping again , it keeps loosing the ip address i think.
Statistics -- xDSL
Mode: ADSL_2plus
Traffic Type: ATM
Status: Up
  Downstream Upstream
SNR Margin (1 dB): 6.0 9.0
Attenuation (1 dB): 39.5 23.9
Output Power (1 dBm): 20.0 12.6
Attainable Rate (Kbps): 9516 340
  Path 0   Path 1
Rate (Kbps): 6653 339 0 0
MSGc (# of bytes in overhead channel message): 94 48 0 0
B (# of bytes in Mux Data Frame): 14 4 0 0
T (Mux Data Frames over sync bytes): 9 3 0 0
R (# of check bytes in FEC Data Frame): 6 14 0 0
S (ratio of FEC over PMD Data Frame length): 0.0716 7.0280 0.0 0.0
L (# of bits in PMD Data Frame): 2346 107 0 0
D (interleaver depth): 416 4 0 0
Delay (msec): 7 7 0.0 0.0
INP (DMT symbol): 4.00 2.00 0.0 0.0
Super Frames: 476929 430970 0 0
Super Frame Errors: 20439 0 0 0
RS Words: 241937171 2466637 0 0
RS Correctable Errors: 3173871 94 0 0
RS Uncorrectable Errors: 14646577 0 0 0
HEC Errors: 126667 0 0 0
OCD Errors: 188 0 0 0
LCD Errors: 188 0 0 0
Total Cells: 63568824 3443324 0 0
Data Cells: 755098 220841 0 0
Bit Errors: 0 0 0 0
Total ES: 500 0
Total SES: 342 0
Total UAS: 417 102
Fixes: 160
Thanks for the answers. It's not loosing the IP address (things don't work that way) but it is loosing synch. Further it looks like the target SNRM has changed.
Does your phone line box have an in-built ADSL filter? If not have you tried a new filter?
Suggest you follow the broadband fault trouble shooter - see links below.
Chris
Legend
Fixes: 169
I'm just testing the line and will post back again shortly.
Chris
Legend
Fixes: 169
Looking at the disconnections on your line is pretty grim viewing:
Test results are showing the line is producing a lot of errors:
  Upstream DSL Link Information Downstream DSL Link Information
Loop Loss: 23.3 39.0
SNR Margin: 16.6 6.6
Errored Seconds: 0 17
HEC Errors: 0
Cell Count: 57 98
Speed: 122 4539
Maximum Stable Rate (KBPS): 9088 Fault Threshold Rate (KBPS): 7270
Mean Time Between Retrains (Seconds): 493 Mean Time Between Errors Upstream (Seconds): 48
Indicative Line Quality: R Mean Time Between Errors Downstream (Seconds): 7
The next step would be to arrange an engineer visit. I'll respond to the fault ticket with that information shortly.
glesgajohn
Does your phone line box have an in-built ADSL filter?= yes
alsoo tried a filter with test socket
Rsebrie
Sorry Chris, not to bother you, but just wanted to say well done on the bar chart with the drops out and all the help you've offered to the Original Poster. Kudos to you.
glesgajohn
the latest info and still dropping out thats a week tomorrow my net been down
 thanx chris 4 ur help
Statistics -- xDSL
Mode: ADSL_2plus
Traffic Type: ATM
Status: Up
  Downstream Upstream
SNR Margin (1 dB): 10.3 20.8
Attenuation (1 dB): 40.0 23.8
Attainable Rate (Kbps): 10892 716
  Path 0   Path 1
Rate (Kbps): 4540 300 0 0
MSGc (# of bytes in overhead channel message): 97 67 0 0
B (# of bytes in Mux Data Frame): 8 4 0 0
T (Mux Data Frames over sync bytes): 10 2 0 0
R (# of check bytes in FEC Data Frame): 8 14 0 0
S (ratio of FEC over PMD Data Frame length): 0.0627 7.6734 0.0 0.0
L (# of bits in PMD Data Frame): 2168 98 0 0
D (interleaver depth): 480 4 0 0
Delay (msec): 8 8 0.0 0.0
INP (DMT symbol): 7.00 2.00 0.0 0.0
Super Frames: 181054 165480 0 0
Super Frame Errors: 3532 1744 0 0
RS Words: 53981733 441291 0 0
RS Correctable Errors: 10162 3888 0 0
RS Uncorrectable Errors: 245 0 0 0
HEC Errors: 4750 5197 0 0
OCD Errors: 0 0 0 0
LCD Errors: 0 0 0 0
Total Cells: 9065155 596356 0 0
Data Cells: 4625501 176716 0 0
Bit Errors: 0 4384 0 0
Total ES: 223 319
Total SES: 120 28
Total UAS: 667 579
glesgajohn
drops inermedietly and if i download.
first time  i went here and was getting 12mb dwnld.
went here every night it drops
http://www.speedtest.btwholesale.com/
at first  it was 12mbit then went to 6 then 1.8 and now (tonight) all i get is 3.94
says
D =3.94
UP =0.35
PING=57.88
went back to here
Statistics -- xDSL
Mode: ADSL_2plus
Traffic Type: ATM
Status: Up
  Downstream Upstream
SNR Margin (1 dB): 8.4 13.9
Attenuation (1 dB): 39.5 23.8
Attainable Rate (Kbps): 11552 516
  Path 0   Path 1
Rate (Kbps): 4539 416 0 0
MSGc (# of bytes in overhead channel message): 97 64 0 0
B (# of bytes in Mux Data Frame): 8 6 0 0
R (# of check bytes in FEC Data Frame): 10 16 0 0
S (ratio of FEC over PMD Data Frame length): 0.0627 8.0000 0.0 0.0
L (# of bits in PMD Data Frame): 2423 128 0 0
INP (DMT symbol): 7.50 2.00 0.0 0.0
Super Frames: 80232 73360 0 0
Super Frame Errors: 994 211 0 0
RS Words: 24686034 193503 0 0
RS Correctable Errors: 8342 0 0 0
RS Uncorrectable Errors: 3 0 0 0
HEC Errors: 353 841 0 0
OCD Errors: 0 0 0 0
LCD Errors: 0 0 0 0
Total Cells: 4145730 374833 0 0
Data Cells: 281465 39064 0 0
Bit Errors: 0 0 0 0
Total ES: 25 42
Total SES: 20 9
Total UAS: 123 103
 Moderator's note by Mike (Mav): Post released from Spam Filter
glesgajohn
glesgajohn
ran flualice since last post but running to slow
glesgajohn
been dropping all day , just done speedtest now only getting
dwnld=1.99
upld=0.03
ping=258.00
this is shocking, thats a week now
all im told is i may be billed 4 engineer, i think plusnet should get their act together
