internet keeps disconecting
glesgajohn
Hi my internet keeps disconnecting (AGAIN) , and i was wondering could someone check this and tell me if anything is wrong, im posting 192 page
thanks for any help
Statistics -- xDSL
Mode: ADSL_2plus
Traffic Type: ATM
Status: Up
Link Power State: L0
  Downstream Upstream
Line Coding(Trellis): On On
SNR Margin (1 dB): 3.1 11.8
Attenuation (1 dB): 40.0 24.8
Output Power (1 dBm): 0.0 12.6
Attainable Rate (Kbps): 9316 556
  Path 0   Path 1
  Downstream Upstream Downstream Upstream
Rate (Kbps): 9219 445 0 0
MSGc (# of bytes in overhead channel message): 51 69 0 0
B (# of bytes in Mux Data Frame): 164 13 0 0
M (# of Mux Data Frames in FEC Data Frame): 1 1 0 0
T (Mux Data Frames over sync bytes): 2 1 0 0
R (# of check bytes in FEC Data Frame): 0 0 0 0
S (ratio of FEC over PMD Data Frame length): 0.5709 0.9333 0.0 0.0
L (# of bits in PMD Data Frame): 2312 120 0 0
D (interleaver depth): 1 1 0 0
Delay (msec): 0 0 0.0 0.0
INP (DMT symbol): 0.00 0.00 0.0 0.0
Super Frames: 0 0 0 0
Super Frame Errors: 66217 969 0 0
RS Words: 0 2051237 0 0
RS Correctable Errors: 0 0 0 0
RS Uncorrectable Errors: 0 0 0 0
HEC Errors: 937023 424 0 0
OCD Errors: 638 0 0 0
LCD Errors: 638 0 0 0
Total Cells: 30900368 1547738 0 0
Data Cells: 1476942 176516 0 0
Bit Errors: 0 359 0 0
Total ES: 18944 823
Total SES: 752 0
Total UAS: 719 200
glesgajohn
Re: internet keeps disconecting
how do i find out the end date of my current contract to cancel. as it ends next month i think , thanks
SpendLessTime
Aspiring Hero
Fixes: 82
Phone, Chat or hope some Plusnet staff member answers.
Fixes: 167
Looking at your line I can see it's disconnected a few times this evening:
  Upstream DSL Link Information Downstream DSL Link Information
Loop Loss: 24.8 40.0
SNR Margin: 5.8 2.6
Errored Seconds: 3 31
HEC Errors: 0
Cell Count: 57789 465285
Speed: 445 9019
Maximum Stable Rate (KBPS): 8128 Fault Threshold Rate (KBPS): 6502
Mean Time Between Retrains (Seconds): 86400 Mean Time Between Errors Upstream (Seconds): 10800
Indicative Line Quality: G Mean Time Between Errors Downstream (Seconds): 252
The SNR is a little lower than I'd like to see on a line with that many errors, which may be causing some issues. I'm going to up it slightly to try and help with the stability, you may see a slight decrease in speed but the disconnections should stop.
 Chris Parr
 Plusnet Staff
glesgajohn
I dont want a decrease in speed, its slow enough as it is , since i joined plusnet i have been told that i had a fault in my line, 12 months later i am bieng told the same , if u cannot supply a reliable service ( which i pay for ) then u cannot expect me  to renew my contract ( up this month )  , i think thats reasonable , do u not ?
glesgajohn
how do i find out the end date of my current contract to cancel. as it ends next month i think , "PLEASE" thanks
glesgajohn
is there not a plusnet user that caan tell me what im asking ? or are u makeing it hard to cancel contract ?
glesgajohn
@ plusnet ..ok fine I will leave, thank you for the BAD SERVICE .
Fixes: 167
Sorry, but the posts on this thread were after we finish on Community for the evening hence no reply.
Looking over your account, the speeds are actually above the top end of the estimates for your line.
I can see you contacted our complaints team and they have replied too.
 Chris Parr
 Plusnet Staff
glesgajohn
can someone check this again (upposed to be fixed )but slow as ? my iplayers are buffering  to
glesgajohn
Statistics -- xDSL
Mode: ADSL_2plus
Traffic Type: ATM
Status: Up
  Downstream Upstream
SNR Margin (1 dB): 8.7 20.0
Attenuation (1 dB): 40.5 25.3
Output Power (1 dBm): 0.0 12.4
Attainable Rate (Kbps): 8752 404
  Path 0   Path 1
Rate (Kbps): 7663 231 0 0
MSGc (# of bytes in overhead channel message): 59 67 0 0
B (# of bytes in Mux Data Frame): 239 7 0 0
T (Mux Data Frames over sync bytes): 1 1 0 0
S (ratio of FEC over PMD Data Frame length): 0.9979 0.9696 0.0 0.0
L (# of bits in PMD Data Frame): 1924 66 0 0
Super Frame Errors: 159981 3660 0 0
RS Words: 0 4092385 0 0
HEC Errors: 2502861 1727 0 0
OCD Errors: 4651 0 0 0
LCD Errors: 4651 0 0 0
Total Cells: 655740626 19779298 0 0
Data Cells: 12432621 1718164 0 0
Bit Errors: 0 563 0 0
Total ES: 25179 1490
Total SES: 2379 36
Total UAS: 1989 696
