internet drops out
mikegodding
internet drops out
Hi, when I leave my computer for ten mins or more , when I get back it shows a yellow triangle on the signal bands and says "LIMITED CONNECTION" so then I have to reset the router via windows help! any idea's people.
Mike Cry
1 REPLY
Fixes: 25
Re: internet drops out
Hi Mike,
Welcome to the forums.
Is your PC wireless or wire connected to the router?  What OS is the PC using?  If this is a wifi connection, is ther router set to a fixed or auto channel?
Are the wifi drivers on the PC up to date?
When you get the problem can you run up a dos prompt and find out he address allocated to the network interface - run ipconfig /all
