internet drops every 10-15 minutes
comancr
Hi guys, I seem to have some issues with the internet that have started yesterday 12/02/2015.
Every 10-15 minutes the internet goes down for about 2-3 minutes. Kind of frustrating.
Is there a know issue in my area or is there something I should do?
Regards,
Cosmin
5 REPLIES 5
plusnettony
Plusnet Staff
Plusnet Staff
Fixes: 18
Re: internet drops every 10-15 minutes
You've got a few lost carriers, and a few RADIUS connection problems but I'm not seeing as many disconnections as you say.
<img src="http://community.plus.net/visualradius/generated/image14238353887567.png"/>
Do you lose sync when the connection drops? Are these drops above when you've been rebooting by any chance?
 Tony T
comancr
I don`t know if actually disconnects but I get timed out packets, I'm constantly pinging recently. Could it have anything to do with my computer?
Chris
Legend
Fixes: 169
Unlikely, those disconnections that we can see are between the router and exchange/us.
However we haven't seen any disconnections since around 2pm. Are you seeing better stability from your side?
comancr
I couldn't be able to tell you as I have been sleeping was doing nightshift. I'll keep an eye on it and see if anything goes wrong again. Thanks for your help.
Fixes: 160
Is the phone line noisy?  Dial 17070 option 2 using a corded phone plugged into the master socket.
If there are crackles / hums / hissing on the line, then raise a noisy line fault with your phone provider, but say nothing about broadband issues.
