internet connection
- internet connection
internet connection
18-11-2014 5:20 PM
Internet connection playing up, on and off every now and then whats wrong with it, seems all wiring connection when its first installed.
Message 1 of 2
(499 Views)
1 REPLY 1
Re: internet connection
18-11-2014 5:22 PM
Your connection is dropping a LOT. Have you made any changes to electrical equipment recently?
I'd strongly advise going through the faults checker at https://faults.plus.net - this will give you some checks and tests to go through and will report the fault to our faults department here.
Message 2 of 2
(343 Views)
