internet connection is intermittent
- internet connection is intermittent
28-04-2014 12:54 PM
asked to start my own thread...
the internet has been quite intermittent of late, losing connection. and there's noise on the phone line. speeds have been quite poor, though today very good - when it's connected.
router box says:
Link Information
Uptime: 0 days, 1:01:00
DSL Type: G.992.5 annex A
Maximum Bandwidth (Up/Down) [kbps/kbps]: 1,292 / 15,996
Bandwidth (Up/Down) [kbps/kbps]: 444 / 14,147
Data Transferred (Sent/Received) [MB/MB]: 6.49 / 75.78
Output Power (Up/Down) [dBm]: 12.0 / 19.5
Line Attenuation (Up/Down) [dB]: 15.5 / 24.0
SN Margin (Up/Down) [dB]: 31.0 / 5.0
Loss of Signal (Local/Remote): 655,351 / 0
Loss of Link (Remote): 0
Error Seconds (Local/Remote): 2,752,478 / 0
FEC Errors (Up/Down): 0 / 92,855
CRC Errors (Up/Down): 0 / 295
HEC Errors (Up/Down): 0 / 10,762
bt says
Download speedachieved during the test was - 10.68 Mbps
For your connection, the acceptable range of speeds is 4 Mbps-21 Mbps.
IP Profile for your line is - 12.48 Mbps
Upload Speed
0.33 Mbps
0 Mbps 0.45 Mbps
Max Achievable Speed
Upload speed achieved during the test was - 0.33Mbps
Additional Information:
Upstream Rate IP profile on your line is - 0.45 Mbps
then it lost connection again just now so...
Uptime: 0 days, 0:00:09
Maximum Bandwidth (Up/Down) [kbps/kbps]: 676 / 12,456
Bandwidth (Up/Down) [kbps/kbps]: 444 / 8,225
Line Attenuation (Up/Down) [dB]: 16.5 / 25.5
SN Margin (Up/Down) [dB]: 14.0 / 9.0
Error Seconds (Local/Remote): 65,538 / 0
FEC Errors (Up/Down): 0 / 29,969
CRC Errors (Up/Down): 0 / 1,023
HEC Errors (Up/Down): 0 / 348
router box says:
Link Information
bt says
Upload Speed
0.33 Mbps
0 Mbps 0.45 Mbps
Message 1 of 4
(1,415 Views)
3 REPLIES 3
Re: internet connection is intermittent
28-04-2014 1:13 PM
Sorry to hear about the issue first of all. No obvious pattern there but it looks like most disconnections are in the afternoon.
<img src="http://community.plus.net/visualradius/generated/image13986870041451.png"/>
Diagnostics and a line test for the noise issue don't show me anything obvious but get this one logged anyway and we'll get you sorted: http://faults.plus.net
Adam
Adam
Message 2 of 4
(536 Views)
28-04-2014 1:48 PM
kahnbarsst,
A really useful set of data - thank you - we can now focus on your issues and not get the other user's thread confused.
The synch rate is somewhat below what might be expected for your line, it should be nearer 18M according to the Kitz calculator. I guess that might be related to the rather high error counts, some of which I note did not get reset (or there is an issue with the router) when you got the resynch.
Also (which is not good news) it looks like the DLM moved the target SNRM to 9dB on that last resynch. This might improve the stability, but that will be at the expense of synch speed.
Something is a miss here, I hope the fault checker Adam pointed to you finds the cause for you. and that BTOR can get it fixed promptly.
Quote @DCT - off topic...
What is the expectation for counter reset on the TG routers when the link is lost? Should they all reset on re-synch or re-establishment of PPP or does the router need a cold (power) boot to clear them all for sure?
I have mixed experiences of seeing the error counters being cleared and also them persisting between (hot) resynchs. May be until seeing this user's stats next to each other I have not looked with enough care?
The LoS counter has not reset.
The Error seconds counter appears as though it might have reset, but is reporting 65,538 which looks like one of those "suspect" binary figures - minus two?
I would not like to take a view on the FEC / HEC / CRC counts beyond stating that if they did reset, then they have gone 'galloping mad' in 9 seconds.
Message 3 of 4
(536 Views)
28-04-2014 2:44 PM
Quote from: _Adam_Walker_ get this one logged anyway and we'll get you sorted: http://faults.plus.net
ok i have done this
Message 4 of 4
(536 Views)
