internet connection dropping out
chappa121170
Hi i have this internet dropping out problem im been ran around by both online chat and calling on my phone
several days ago i was asked to swap the connection to the "test socket" this has been done and its still dropping the connection between 5 and 15 times per day so much so its making me rethink weather i should move to another provider i want the line testing and checking to see what the fault is on my line
Gel
Seasoned Pro
Fixes: 14
Re: internet connection dropping out
Plusnet Staff
Plusnet Staff
Fixes: 117
Hi there @chappa121170 I am sorry to hear you're having connection problems. I've tested your line and I'm not identifying the cause of the drops. I'd advise to complete the broadband troubleshooter at http://faults.plus.net
Let us know on here once you've done that and I'll progress the fault as soon as I can.
From when I joined the Plusnet Help Team in May 2017 my main Community account is @Gandalf.
 Plusnet Staff
chappa121170
since i put new router on its been stable fingers crossed it was old thompson router that wasnt performing like it should
Plusnet Staff
Plusnet Staff
Fixes: 117
Fingers crossed it remains that way
 Plusnet Staff
williams1963
I am having the exact same problem, just waiting for an engineer if he /her  tells me there is nothing wrong, (which I highly expect him/her to say) then I am paying to get out of my contract and going, fed up with the service from Plusnet and being run around the house, the blany that they are obviously reading from a script stinkks of bull doo doo.
Fixes: 163
Hi @williams1963
Apologies that you're having connection issues. Unfortunately although the symptoms may be similar, the underlying cause can vary massively.
I've checked over your account and can see an engineer visit was arranged. The line does appear be be stable for nearly 24 hours since this now, if you do continue to have issues please get back to us and let us know.
 Chris Parr
 Plusnet Staff
williams1963
It would appear according to the engineer that it was your fault all along, something about the provider only sending a signal strength of 3 down the line when it should be at least a 6, he (the engineer) has now boosted it back u to a 6 and I also gained a meg of speed
Fixes: 163
That sounds like they've altered the SNR on the line, this is something that is controlled automatically by the dynamic line management in the exchange and should automatically update depending on the line conditions. If this is too low then it can cause disconnections, raising it will often cause the speed to drop. I'm very glad they found the issue for you and resolved this.
 Chris Parr
 Plusnet Staff
