intermittent loss of routing ? plusnet
myforumid
My connection occasionally needs a kick (this morning it took 5 mins to reconnect) but whenever i go to disconnect/reconnect it seems to still have sink and thinks all is well. All is not well until it is reconnected though.
i am wondering what I should look for. I have:
- configured static IP
- disabled SPI firewall (my router was periodically complaining about packets from the plusnet DHCP servers..)
- installed dgteam and configured additional dns servers (opendns)
- toyed with the always broadcast ARP setting having read a post about this
i am currently toying with a router script that tries to lookup a web address every 30 minutes and reconnects adsl if that fails however
does anyone have any thoughts on what might cause this?
should i try to dial down the speed (dial up the noise margin?) i have not touched that as yet.
the router is capable of operating for 2 weeks+ straight with no issues and i feel the old one probably was binned for similar reasons but in error. all the caps on the main board are new and it is a *very well ventilated* dgn2000.
Fixes: 20
Re: intermittent loss of routing ?
Perhaps some list or table for tracking connections within the router ends up full, for some unknown reason, and gets completely cleared when you reconnect.
myforumid
hmm ok ... any clues on which tables i might check .. presumably telnet etc to the netgear will help ... i will have a nose around
cant think what would be unique to me though ... this is stock netgear and have had 3 firmwares now .. just went to dgteam a month ago
myforumid
I havent found anything abnormal - wondering how i get one of those line noise plots in case it is purely a line issue?
Re: intermittent loss of routing ? plusnet
Hi myforumid,
Below is a post of the your last month's connections logs:
<img src="http://ccgi.psmith12.plus.com/visradius/generated/image13440056759248.png" />
There is no pattern to your disconnections. I've checked your line and everything initially appears to be OK.
Have you tried an alternative router?
myforumid
Very useful plot -  it ties up with the router logs i have.
There are clearly times when the router knows to reconnect and times when it doesnt realise its lost the session and just sits there doing nothing about it. I figure i need it to ping an address or something periodically and adsctl restart or whatever if it can't get a response. A friend suggested just enabling ddns might do it but this is probably a shell script on a schedule.
Its my third in 3 years and moving house soon - waiting on a site survey of the new place etc. before investing :-)
If you need any further help once you've moved let me know.
Chris
