intermittent disconnections
- Re: intermittent disconnections
22-05-2010 11:52 PM
Evening all,
I'm getting intermittent disconnections, usually one or two per day, so nothing too major. There's something rather odd about it though. The connection drops, I reboot the router and despite it showing a green light for the internet as though it's working fine it still doesn't work. So i reboot a second time and then it works fine.
This happens without fail every time. Two router reboots and then the net's working fine for a few hours.
The connection's interleaved with a direct connection into the master socket and a 2m cable so cabling's not the issue. Any ideas?
Message 1 of 5
(888 Views)
4 REPLIES 4
23-05-2010 2:17 AM
i'm getting intermittent disconnections and have found that if i leave it for a couple of minutes, it's ok again. it appears that sometimes it's a website falling over and at others a gremlin passing through the works.
i used to do what you do, reboot the router, start and stop my connection, reboot the computer. now all i do is apply a modicum of patience - go and make a cup of tea. by the time i come back, it's ok.
Message 2 of 5
(420 Views)
23-05-2010 10:49 AM
Your not using a Netgear DG834G by any chance are you as I've seen that happen with them?
Quote from: Banality
Message 3 of 5
(420 Views)
23-05-2010 11:08 AM
I am actually using a Netgear DG834G
Message 4 of 5
(420 Views)
23-05-2010 1:04 PM
I am getting disconnects but still doing tests at my end.
I intend to try two other routers DG834G and a BT2700.
I am using a DG834GT with DGteam Firmware but will try Netgear firmware as well.
Strange thing is it is stable for hours then all of a sudden it seems to go vary unstable and at any time of the day and I can't see any pattern.
One thing I would recommend to others it do not log any rules in DG834 routers as I have found that used up memory and router fell over, that may explain why a reboot fixes it.
Message 5 of 5
(420 Views)
