intermittent connection faults
- intermittent connection faults
10-04-2011 6:20 PM
Hello,
Just looking for a bit of advice on my connection. I've start having the same problem as 2 years ago,please see link below
http://community.plus.net/forum/index.php/topic,75924.msg609951.html#msg609951
I tried to change a microfilter,swap a router,used a different corded phone still with random crashes.There doesn`t appear to be any particular pattern to my line losing connection.I am using a test socket for now with router and microfilter connected and nothing else.I didnt loose a connection but there is huge spike(see graph below).I tried a quiet line test with corded phone with and without router connected and I didnt hear any white noise or crackling on the line in both cases only when router was connected there was a big change in noise margin 7 db drop at 17:54 another drop at 18:07 after trying quiet line test again.
Could anyone help me please?
Here are my stats from router netgear DG834 v.4
System Up Time 01:42:27
Port Status TxPkts RxPkts Collisions Tx B/s Rx B/s Up Time
WAN PPPoA 139342 130803 0 2022 5027 01:41:47
LAN 10M/100M 136239 148015 0 5773 2665 01:42:23 WLAN 11M/54M 0 0 0 0 0 00:00:00 --
ADSL Link Downstream Upstream
Connection Speed 7584 kbps 448 kbps
Line Attenuation 32 db 9 db
Noise Margin 11 db 26 db
Message 1 of 3
(922 Views)
2 REPLIES 2
Re: intermittent connection faults
11-04-2011 10:32 AM
Does the noise happen when any router is plugged in, and the same with any filter? I'd have said it was either of those at fault if the noise only happens when the router is plugged in.
Message 2 of 3
(437 Views)
11-04-2011 11:15 AM
I changed to master socket yesterday and until now it look stable for 12 hours (according routerstat).I'll try to test the other router if there is a noise fluctuation with the phone connected when my ip profile bump up.(which can take 3 days )
Message 3 of 3
(437 Views)
