interleaving
- interleaving
Re: interleaving
14-05-2015 5:23 PM
Here are the stats
Uptime: 0 days, 8:58:34
DSL Type: ITU-T G.992.5
Bandwidth (Up/Down) [kbps/kbps]: 1,005 / 5,145
Data Transferred (Sent/Received) [GB/GB]: 1.06 / 15.05
Output Power (Up/Down) [dBm]: 12.8 / 0.0
Line Attenuation (Up/Down) [dB]: 27.3 / 51.0
SN Margin (Up/Down) [dB]: 5.8 / 5.7
Loss of Framing (Local/Remote): 9 / 0
Loss of Signal (Local/Remote): 1 / 0
Loss of Link (Remote): -
Error Seconds (Local/Remote): 76,658 / 0
FEC Errors (Up/Down): 920 / 1,143,012
CRC Errors (Up/Down): 97 / 420
HEC Errors (Up/Down): 124 / 4,650
I had a look last night didn't copy the stats though but the CRC Errors were a million plus (down)
so it looks like Interleaving been put back on to keep them down.
Im still plugged into the master socket with a mircofilter no other phones plugged in ./
The boys Pings have gone back up to about 50-60 not spiking as much fingers crossed.
I think my line needs to be looked at , what do you guys think
Re: interleaving
14-05-2015 8:50 PM
Have you tried the Quiet Line Test a few times?
Something is definitely going on, the US SNRM had (not for the first time) dropped to 3.8 after the reset but within 10 minutes was back to 5.4 and since the drop and Interleaving turning on, is now 5.8 with a similar US sync speed. It looks as thought the DS Target SNRM may have gone to 6dB with the slower DS speed.
Let us know how your streaming is with this speed?
Can you also post the version of Firmware on your TG582n - you'll find it in the Technicolor Gateway box (at the top) - Software Release.
Re: interleaving
15-05-2015 5:27 AM
Quite line test I've done a few times but i can't hear anything that sounds untoward
Gaming was so much better with interleaving off (its like night and day)
Product Name: TG582n
Software Release: 10.2.2.B
Some stats from this morning
Link Information
Uptime: 0 days, 21:14:58
Data Transferred (Sent/Received) [GB/GB]: 1.63 / 23.84
SN Margin (Up/Down) [dB]: 6.1 / 6.1
Error Seconds (Local/Remote): 76,919 / 0
FEC Errors (Up/Down): 1,273 / 2,558,850
CRC Errors (Up/Down): 105 / 1,077
HEC Errors (Up/Down): 128 / 10,654
Re: interleaving
15-05-2015 9:31 AM
Quote from: scottymc Quite line test I've done a few times but i can't hear anything that sounds untoward
You shouldn't be able to hear anything at all apart from a very very faint steady hiss/mush.
The fact that the CLT didn't show anything, doesn't mean that there isn't an intermittent iffy connection somewhere.
Try the ringback on Option 1, let it ring until it stops.The ringing current may help improve any joints that aren't 100%.
In the meantime you will need another order to turn Interleaving OFF this time, not just to Auto.
Re: interleaving
15-05-2015 3:24 PM
I'll do option 1 when i get home tonight.
If Chris /Tony are reading this please could you get Interleaving turned off and not turned to auto, I think that's the best option for gaming by far.
Thank again for everyone's help
Re: interleaving
15-05-2015 5:22 PM
Re: interleaving
15-05-2015 5:54 PM
Here are my stats i think it is on
Link Information
Uptime: 1 day, 9:39:26
Data Transferred (Sent/Received) [GB/GB]: 2.11 / 38.71
SN Margin (Up/Down) [dB]: 6.2 / 6.1
Error Seconds (Local/Remote): 77,073 / 0
FEC Errors (Up/Down): 2,450 / 4,641,057
CRC Errors (Up/Down): 261 / 1,372
HEC Errors (Up/Down): 421 / 12,847
Re: interleaving
15-05-2015 5:56 PM
Interleaved upstream doesn't always limit the speed to 888kbps
Re: interleaving
15-05-2015 5:59 PM
There are some strange goings on, on this line. If we can get Interleaving back off, at least his kids will be gaming OK whilst we see if we can discover what might be going on.
Re: interleaving
15-05-2015 7:26 PM
Re: interleaving
15-05-2015 7:26 PM
Interleaving is now off
Stats
DSL Type: ITU-T G.992.3
Bandwidth (Up/Down) [kbps/kbps]: 1,039 / 4,687
Data Transferred (Sent/Received) [GB/GB]: 2.33 / 40.05
Line Attenuation (Up/Down) [dB]: 27.3 / 47.5
Loss of Framing (Local/Remote): 17 / 0
Loss of Signal (Local/Remote): 2 / 0
Error Seconds (Local/Remote): 77,203 / 0
FEC Errors (Up/Down): 0 / 0
CRC Errors (Up/Down): 0 / 251
HEC Errors (Up/Down): 0 / 36
and the line seems to be shorter ??
well looking at the Line Attenuation anyway
but what do i know ?
Re: interleaving
15-05-2015 7:27 PM
Re: interleaving
15-05-2015 8:21 PM
If you can post some more stats later if convenient, or sooner if you see any significant changes in SNRM.
I think we'll have to consider a bit of more detailed monitoring and I'll post back later with that suggestion.
In the meantime be a bit OCD with the Quiet Line Test, and the Ringback test.
Re: interleaving
15-05-2015 9:45 PM
here are some more stats
Link Information
Uptime: 0 days, 2:21:06
Data Transferred (Sent/Received) [GB/GB]: 3.19 / 43.51
SN Margin (Up/Down) [dB]: 6.3 / 6.0
Error Seconds (Local/Remote): 82,598 / 0
CRC Errors (Up/Down): 8 / 13,879
HEC Errors (Up/Down): 4 / 2,594
lose of 500kbps is a kick in the go-nads but is what it is mind you last week when you first turned interleaving off i re-synced @ 5706 fastest ever mind you my SN Margin was 3dB
Re: interleaving
15-05-2015 10:07 PM
Is it because I'm on this DSL Type: ITU-T G.992.3 instead of this DSL Type: ITU-T G.992.5
Why did you change it ? only wanted interleaving turned off
do you think if i reboot the router it would change back ?
or is it something you guys have to do ?
