improing m upload speed?
- improing m upload speed?
11-03-2014 10:44 AM
i'd like to have a better upload speed, i heard that our upload speeds were capped around 0.44, so i just added the pro add on for gaming thinking it would improve my upload but it is still capped at 0.44 when i did the speed test.
is there another way to get this uncapped.
Help would be appriciated.
Re: improing m upload speed?
11-03-2014 10:47 AM
11-03-2014 10:48 AM
11-03-2014 10:52 AM
11-03-2014 10:59 AM
11-03-2014 11:01 AM
Link Information
Uptime: 1 day, 14:51:36
DSL Type: ITU-T G.992.1
Bandwidth (Up/Down) [kbps/kbps]: 448 / 2.496
Data Transferred (Sent/Received) [MB/GB]: 785,80 / 1,83
11-03-2014 11:03 AM
11-03-2014 11:05 AM
Results: Weston-super-Mare Code: SSWSM
County: Avon
Enabled: 12 Jul 2001
Market: 3
Mkt2014: B
20CN VP capacity at this exchange is currently showing as Green.
Click here for further details
BT have advised that this exchange is enabled for WBC on 21CN
You can view recent Service Outages for this exchange here
BT have published Max DSL upgrade information for this exchange
Bookmark this exchange here
Back to exchange search
Mkt2014 is the new market classification proposed in the Ofcom consultation paper Review of the wholesale broadband access markets published on 11/07/2013. This is given here for information only; there is no guarantee that Ofcom will adopt these classifications at the end of the consultation, and they might change any assigned values. Also how Plusnet will use them is to be announced.
11-03-2014 11:09 AM
This will need a member of staff to confirm and, if this is the case, initiate the move to 21CN
If you are already on 21CN then the upload just needs uncapping
11-03-2014 11:12 AM
11-03-2014 11:14 AM
11-03-2014 11:17 AM
11-03-2014 11:26 AM
I believe you're on ADSL Max from your router stats (G.992.1) which I think means you might not have been moved across to 21CN.
Have you also looked at if fibre is available in your area?
11-03-2014 11:29 AM
i just wanted better upload while im waiing for it to be installed to be able to use twitch
11-03-2014 11:37 AM
I am not entirely sure how much of an improvement you will see in your upload speed on your ADSL - because you obviously live a fair distance from your exchange.
Is Twitch like Youtube? You shouldn't have any problems with that with your ADSL connection. I don't think uncapping your upload (if you're moved to 21CN) will make any difference. On noisy lines (like yours), uncapping the upload can be counter-productive and cause instability on the line.
