iPlayer always needs re-installation
Fixes: 228
Every time I start a new download using iPlayer Desktop (the current download list being empty) I am asked to install the player.
It goes through the iPlayer Download (Air) then I get a message
The same version of the application you opened already exists on this system and is running.
You must close the open application before continuing.
This time I clicked Cancel so the program I wanted to download has not appeared.
If I exit iPlayer from the Taskbar notification area then I still sometimes have to re-install iPlayer destop. I'm running W7 32 bit.
Has anyone else met with this?
Forum Moderator and Customer
