i player stops router
- i player stops router
26-08-2015 3:24 PM
When I try to use bbc i player it runs for a minute or so and then the broadband fails and has to be left to connect again, My connection is only about 1 meg but has worked before
Message 1 of 3
(499 Views)
2 REPLIES 2
Re: i player stops router
27-08-2015 7:38 AM
this is strange I'm having the same problem and my ip is usually 2.5-3 have you tried others like 4OD because that did the same as iplayer with my router , good luck if you get it sorted let us know
Message 2 of 3
(340 Views)
27-08-2015 9:34 AM
Well I have replaced my BT router with a Technicolor one and all seems O K so can only asume router was at fault
Message 3 of 3
(340 Views)
