i need these ports open
reece251
hi i need these ports open
UDP: 3074; 3659; 6000
TCP: 80; 443; 3659; 10000 - 10099; 42127
how can i do it because its asking for a start port number and an end port number?
Re: i need these ports open
Use the same number for both the start and end ports for the single port ones
reece251
what do i do about the one with the dash inbetween
Use start port 10000 and end port 10099. That will open all ports from 10000 to 10099
