i.imgur.com blocked since 13th March
tobyhamand
I've noticed that a site I frequency visit (reddit.com) has had all its images from the image hosting site imgur.com blocked by plus.net. I have discussed the problem with other plus.net customers.
Why has this website been blocked and how do I go about unblocking it without using a proxy?
Toby
Fixes: 55
Re: i.imgur.com blocked since 13th March
Presumably some its content is on the IWF list mentioned here.
David
Azagoth
I too cannot load any images hosted on imgur.com, and also the images on http://www.blu-ray.com/ won't show either.  Yet if I go in via a proxy, both site's images load just fine.
EDIT:  Looks like 4chan is having the same problem too, no images load normally.  Yet if I jump onto my neighbours Virgin connection they load just fine.  So considering that Virgin also adhere to the IWF list and the images load on their connection, then logic dictates that it isn't the IWF blocking the images from loading.  It has to be something at Plusnet.
pierre_pierre
just checked blue ray.com works for me as does redit.com
Fixes: 86
Quote from: pierre_pierre
Struggling here on thn-ag1. I'll do some digging (no pun intended BTW with reddit being one of the sites affected Roll eyes )...
belperite
Hello, i.imgur.com is indeed currently being blocked by the IWF due to what looks like a single dodgy image on the whole site. I'm raising a change to get i.imgur.com whitelisted for you which should be done by the end of today with any luck Smiley
tobyhamand
Quote from: belperite
Thanks, it looks like its just become whitelisted!
belperite
Hi there, i.imgur.com should now be OK, please post up if you have any further problems Smiley
Fixes: 86
Seems OK for me! Smiley
