how to stop getting frequent disconnections (guide)
paqize
dont ask me why or how it works, ask plusnet!  Lips are sealed
1. go into the router and reset to factory default.
2. add new user with admin rights and set it to default user.
setting up your username and password is not required!
let me know if this works for you.
you might also wanna use the command line to change the admin password manually because changing it from router page is impossible; again ask plusnet why!
Mand
Re: how to stop getting frequent disconnections (guide)
Strange, never heard of that before, and can't see *why* it would fix anything.
Re the admin password, I believe that's a firmware limitation.
paqize
it worked for me thrice in one day, it's hard to believe it coincidence.
yeah the admin pass can only be changed via command line, but you can still reset it from gui web page.
