how to safely disconnect when power needs to be cut
- Re: how to safely disconnect when power needs to b...
26-11-2014 11:39 AM
been having work done in the house since Friday last week, that has required the power to be cut a few times.
what i've been doing is dropping the PPP connection then turning the router off - once per day when it's been required.
i assume this is the correct way to do it to stop DLM kicking in and thinking something is a-miss?
every time i've reconnected my sync speed has remained the same (give or take a few Kbps here and there) - always 17Mbps+
Message 1 of 4
(720 Views)
3 REPLIES 3
Re: how to safely disconnect when power needs to be cut
26-11-2014 11:42 AM
Spot on, that's the way we'd advise.
Message 2 of 4
(418 Views)
26-11-2014 9:34 PM
Quote from: chenks76 what i've been doing is dropping the PPP connection then turning the router off
Sorry, just curious... So log in to router and click disconnect? I've always just pulled the plug to turn off / restart my router. Is that wrong?
Quote from: chenks76 stop DLM kicking in and thinking something is a-miss?
What's DLM?
Message 3 of 4
(418 Views)
26-11-2014 10:47 PM
Dynamic Line Management
Message 4 of 4
(418 Views)
