how reliable is BT speedchecker
- how reliable is BT speedchecker
01-02-2009 4:15 PM
My SNR was reset again this week and appears to be holding. My Line speed has increased along with my sync.
I decided to try the BT test to check my throughput what do people make of these results. Some sites I can download from at 400kbps. Webpages are often slow to load even pn and the like of goole and bbc
In master socket.
Bt speedtest
0:30 Sunday 1st Feb
Test1 comprises of Best Effort Test: -provides background information.
Your DSL connection rate: 5728 kbps(DOWN-STREAM), 448 kbps(UP-STREAM)
IP profile for your line is - 4500 kbps
Actual IP throughput achieved during the test was - 801 kbps
10:37 Sunday 1st Feb
Actual IP throughput achieved during the test was - 797 kbps
16:08 Sunday 1st Feb
Actual IP throughput achieved during the test was - 567 kbps
In master socket.
Bt speedtest
0:30 Sunday 1st Feb
Message 1 of 7
(1,404 Views)
6 REPLIES 6
Re: how reliable is BT speedchecker
01-02-2009 4:34 PM
what do you get at http://www.mybroadbandspeed.co.uk/. i have noticed of late that bt speed result comes back as 3 figuers but testing on multpule diffrent speed test sites my speed is as normal.
have you got your mtu/rwin set right on your pc?. if you have vista that does the rwin auto. but if you have xp then drtcp program worth playing with.
Message 2 of 7
(663 Views)
01-02-2009 5:17 PM
What does https://portal.plus.net/my.html?action=stable_rate say for your current line speed?
Message 3 of 7
(663 Views)
01-02-2009 7:23 PM
my broadband speed
and
See also
http://www.dslzoneuk.net/speedtest/speedtest.php?id=976925
BT Test 19:22
Actual IP throughput achieved during the test was - 620 kbps
If you wish to discuss these results please contact your ISP.
If you are experiencing problems with specific applications, servers
http://www.dslzoneuk.net/speedtest/speedtest.php?id=976929
Line rate shows as 4500
and
See also
BT Test 19:22
Message 4 of 7
(663 Views)
02-02-2009 9:17 PM
Looks like contention/congestion at peak times. Try running a few tests just before midnight, or in the early hours (not 12-1am) or first thing in the morning.
Also check your exchange VP status here.
Might be worth noting which Gateway you are on and looking at the packet drops here.
Message 5 of 7
(663 Views)
02-02-2009 9:32 PM
PN are looking into it.
Curently on pcl-ag01.
Graph shows a high number of dropped packets for un identified traffic. (correction there not a high no of drops it is not obvious that the scal may be different across all the graphs)
last test 1hr ago has results that were a bit more like it.
Your DSL connection rate: 5152 kbps(DOWN-STREAM), 448 kbps(UP-STREAM)
Actual IP throughput achieved during the test was - 4027 kbps
Message 6 of 7
(663 Views)
02-02-2009 10:36 PM
just done a VP test (I was also surprised anotherone)
Your DSL connection rate: 8128 kbps(DOWN-STREAM), 448 kbps(UP-STREAM)
IP profile for your line is - 7150 kbps
Actual IP throughput achieved during the test was - 1132 kbps
Quote red Virtual paths: Red
BT is reporting that some of the virtual paths at this exchange are not operating within BT Wholesale's planning guidance, although they are still operating within the product specification.
At busy times, your ADSL connection may operate at a reduced speed, although not all customers on your exchange may be affected. You should only contact support if there is no current ETA date set.
The ETA fix time is: 28 Jan 09
Record last updated: 12 Jan 09
Historical information for this exchange:
Status Date
red 05 Jan 09
Message 7 of 7
(663 Views)
