how do you stop the noise margin from continuing to fall?
rockfall
These are my stats:
Uptime: 0 days, 4:36:44
DSL Type: G.992.5 annex A
Bandwidth (Up/Down) [kbps/kbps]: 444 / 12,832
Output Power (Up/Down) [dBm]: 12.0 / 21.0
Line Attenuation (Up/Down) [dB]: 19.0 / 34.0
SN Margin (Up/Down) [dB]: 21.0 / 3.0
Vendor ID (Local/Remote): TMMB / TSTC
Loss of Link (Remote): 0
Error Seconds (Local/Remote): 8 / 0
FEC Errors (Up/Down): 0 / 2,385,084
CRC Errors (Up/Down): 0 / 442
HEC Errors (Up/Down): 1,418 / 401
Surely the noise margin will drop too far soon and i'll have connection problems? I also have a lot of FEC errors, does anyone know what they are?
Tony
rockfall
Re: how do you stop the noise margin from continuing to fall?
Noise margin went back upto 4.5db this morning and it was still synced. Is it safe for it to be low?
jojopillo
Hi rockfall,
When the noise margin is low like this then there would only be an issue if there were noise spikes. It seems from your connection logs that your connection is stable so I wouldn't worry too much about that. As far as the errors go, they do look like a lot I agree, the router will be reporting errors that are corrected so I wouldn't pay to much heed to the numbers. You can see from your stats that there are only 8 error seconds. This is from an uptime of 4hr36min44secs (16604 seconds) which doesn't look so bad  when you look at it like that, does it?
Jojo Smiley
rockfall
Ok Jojo many thanks for clarifying.
Tony
