hope you can help jameseh.-speed setting problem
- Re: hope you can help jameseh.-speed setting probl...
17-04-2008 4:08 PM
Hi Jameseh,hope tottenham improve for you but to my wee problem,with nothing changed,my speed has been put down to 1500 from 2000,there doesnt seem any cause at my end,just wondering if you could change it back to 2000 mate.I have had this happen only 1 time before,you did the business and we were back to our good old selves.I could grovel and tell you i will support the spurs in future but id only be lying mate.Kindest, ;)kindest regards and i hope im not being to much of a bad boy asking on the forums but thats why we win awards isnt it.Oh and up the o
System Up Time 00:37:01
Port Status TxPkts RxPkts Collisions Tx B/s Rx B/s Up Time
WAN PPPoE 16928 16317 0 1682 2490 00:36:33
LAN 10M/100M 17094 17694 0 2791 1870 00:36:57
WLAN 11M/54M 0 0 0 0 0 00:00:00
ADSL Link Downstream Upstream
Connection Speed 2208 kbps 448 kbps
Line Attenuation 60.0 db 31.5 db
Noise Margin 10.4 db 16.0 db
Message 1 of 9
(1,530 Views)
8 REPLIES 8
18-04-2008 9:34 AM
Hi Jameseh,hope tottenham improve for you but to my wee problem,with nothing changed,my speed has been put down to 1500 from 2000,there doesnt seem any cause at my end,just wondering if you could change it back to 2000 mate.I have had this happen only 1 time before,you did the business and we were back to our good old selves.I could grovel and tell you i will support the spurs in future but id only be lying mate.Kindest, ;)kindest regards and i hope im not being to much of a bad boy asking on the forums but thats why we win awards isnt it.Oh and up the owls
Message 2 of 9
(724 Views)
Re: down from 2000 to 1500 ( for jameseh)
18-04-2008 10:10 AM
Sorry i asked.
kind regards ray.up the owls.
Message 3 of 9
(724 Views)
Re: hope you can help jameseh.-speed setting problem
18-04-2008 10:16 AM
Sorry i asked.
kind regards and up the owls.
Message 4 of 9
(724 Views)
18-04-2008 10:28 AM
May I suggest you read the <a href="http://www.plus.net/support/customer_service/community/forum.shtml">forum rules</a> - particularly the part about cross posting
Message 5 of 9
(724 Views)
18-04-2008 10:30 AM
Spurs > Owls
It looks like your sync speed has gone down a little bit:
Which has put you onto a 1500Kbps profile. I'd try a few reboots and see if those values change at all.
Quote Connection Speed 2208 kbps 448 kbps
Message 6 of 9
(724 Views)
18-04-2008 11:42 AM
Denzil,may i ask you to read again what ive just wrote above your last post when i realised id been a bad boy,it did say sorry i asked and thanks for the reminder about doing the wrong thing.
Message 7 of 9
(724 Views)
18-04-2008 11:45 AM
Thanks for the reply jameseh,even though its been pointed out i did it the wrong way.up the owls.
Message 8 of 9
(724 Views)
18-04-2008 11:50 AM
mod:note
Cross post, merged.
Jonathan
Cross post, merged.
Jonathan
Message 9 of 9
(724 Views)
