high ping on 1st hop
- high ping on 1st hop
20-05-2014 12:19 PM
when i do a tracert i have high ping on 1st hop around 96ms is that normal.and would that cause latency problems for gaming
Message 1 of 5
(1,309 Views)
4 REPLIES 4
Re: high ping on 1st hop
20-05-2014 12:23 PM
If its a technicolor router yes that is normal
FTTP 500 regrade from Tues 28th November
Message 2 of 5
(337 Views)
20-05-2014 12:36 PM
so not going to cause me problems when gaming?
Message 3 of 5
(337 Views)
20-05-2014 12:45 PM
Unless its higher than 99 and as long as the rest of the hops are normal its ok.
Message 4 of 5
(337 Views)
20-05-2014 12:54 PM
ok mate thanks
Message 5 of 5
(337 Views)
