help....
- help....
- « Previous
- 1
- 2
- Next »
Re: help....
26-04-2010 4:16 PM
Re: help....
26-04-2010 4:18 PM
Re: help....
26-04-2010 4:24 PM
Re: help....
26-04-2010 4:26 PM
Re: help....
26-04-2010 4:32 PM
because im really losing heart and patients with all of this now...
Re: help....
26-04-2010 4:51 PM
We can't book appointments on the same day as they're requested I'm afraid. It might be that an engineer has already been tasked from the fault, but this is extremely unlikely.
Rest assured we'll get it sorted as soon as is possible.
Re: help....
26-04-2010 4:56 PM
Re: help....
26-04-2010 5:06 PM
However, the following test can help check if you are on Tiscali LLU, but please bear in mind that the test will also work if you are on a Tiscali DataStream service.
You will need to change your router or modem settings to the following:-
username: testing@dslconnect.co.uk
password: testing
From there you may also be able to navigate to: http://www.dslconnect.co.uk
i have just tried that and it let me log in with that on my router so i am still on a LLU network!
Re: help....
26-04-2010 5:12 PM
You can't still be on the LLU network as you've got a working connection to us, I'm not sure why the dslconnect login is working - it's most likely related to the fault but if you hadn't been moved back you wouldn't be able to connect to us at all. We'll keep an eye on it for you and let you know as soon as there's any more information.
Re: help....
26-04-2010 5:15 PM
Re: help....
26-04-2010 5:21 PM
I don't doubt that the dslconnect login worked, I'm just saying that the reason it worked wasn't because the jumpering wasn't done. I'm afraid I don't know why it did work though.
Re: help....
26-04-2010 5:24 PM
Re: help....
26-04-2010 5:45 PM
- « Previous
- 1
- 2
- Next »
