help with udp and tcp settings on a Technicolor TG582n FTTC
- help with udp and tcp settings on a Technicolor TG...
27-01-2017 11:39 AM
Hi everybody,
I am an avid gamer and play multiple platforms however i have an issue on a console game called warframe on the playstation 4, due to the limitations of the console i am in need of changing settings on the router in order for myself to be able to play freely with others on the online multiplayer mode.
The game troubleshoots this as allowing the following settings to be tweaked in order for it to run in optimum condition,
Warframe uses UDP ports 4950 - 4955 & the TCP port range 6695 - 6699
After speaking to customer services and them not having the technical knowledge i am left in frustration as i do not know how to apply these settings once im logged in to the router please help.
my router is a Technicolor TG582n FTTC
many thanks,
BT
Re: help with udp and tcp settings on a Technicolor TG582n FTTC
27-01-2017 12:01 PM
I don't have that router but this thread discusses how to https://community.plus.net/t5/Broadband/Technicolor-TG582n-port-forwarding/td-p/976748 with varying degrees of success.
