help setting up dlink dir 655
- Re: help setting up dlink dir 655
31-03-2013 11:17 PM
01-04-2013 9:54 AM
See page 20 of the dir 655 manual ( http://static.highspeedbackbone.net/pdf/D-link-DIR-655-Manual.pdf ) for details of how to setup a PPPoE connection.
Select Dynamic for the Address mode and Always On for the reconnection mode.
Hope that helps
01-04-2013 12:15 PM
01-04-2013 12:19 PM
01-04-2013 12:31 PM
connecting modem to router then router to laptop via Ethernet.
iv tried: manual setup
PPPoE
dynamic ip and static ip.
entered ip address on static.
username-
password
always on
iv tried typing in dns server
do you need to clone mac address or leave it, iv tried both.
01-04-2013 1:32 PM
You could try connecting the laptop directly to the modem and making a direct pppoe connection just to test the login details.
See here for Xp http://community.plus.net/library/broadband/fibre-help-setting-up-a-pppoe-dialler-for-windows-xp/ or here for vista/w7 http://community.plus.net/library/broadband/fibre-help-how-to-set-up-a-pppoe-dialler-in-vistawindows...
01-04-2013 3:19 PM
01-04-2013 5:18 PM
02-04-2013 3:49 PM
Have you tried leaving it for a while and seeing if it eventually connects, either that or does it have a log you could look at for any errors like those in that thread ?
Edit: if does look like the dir655 has a half decent logging capability ( manual page 59 ) , make sure all the options are checked and then restart it and see if there are any pppoe logs that might give us an indication of what's wrong.
